Help Center/ Cloud Container Engine/ FAQs/ Networking/ Network Configuration/ Why Is the Backend Server Group of an ELB Automatically Deleted After a Service Is Published to the ELB?
Updated on 2026-01-05 GMT+08:00
Symptom
After a Service is published to ELB, the workload is normal, but the pod port of the Service is not published in time. As a result, the backend server group of the ELB is automatically deleted.
Answer
- If the ELB health check fails during ELB creation, the backend server group will be deleted and will not be added to the ELB even if the Service becomes normal. If an existing SVC is updated, the backend server group is not deleted.
- When a node is added or deleted, the node access mode in the cluster may change due to the cluster status change. To ensure normal service running, the ELB performs a refresh operation. The process is similar to that of updating the ELB.
Suggestions
Optimize the application to speed up the startup.
