How Do I Expand the Storage Capacity of a Container?
Application Scenario
The default storage size of a container is 10 GiB. If a large volume of data is generated in the container, expand the capacity using the method described in this topic.
Solution
- Choose Nodes from the navigation pane.
- Click the Nodes tab, locate the row containing the target node, and choose More > Reset Node in the Operation column.
Resetting a node may make the node-specific resources (such as local storage and workloads scheduled to this node) unavailable. Exercise caution when performing this operation to avoid impact on running services.
- Reconfigure node parameters.
If you need to adjust the container storage space, pay attention to the following configurations:
Storage Settings: Click Expand next to the data disk to configure the following parameter:
Space Allocation for Pods: indicates the base size of a pod. It is the maximum size that a workload's pods (including the container images) can grow to in the disk space. Proper settings can prevent pods from taking all the disk space available and avoid service exceptions. It is recommended that the value is less than or equal to 80% of the container engine space. This parameter is related to the node OS and container storage rootfs and is not supported in some scenarios.
For more information about container storage space allocation, see Data Disk Space Allocation.
- After the node is reset, log in to the node and check whether the container capacity has been expanded. The command output varies with the container storage rootfs.
- Overlayfs: No independent thin pool is allocated. Image data is stored in dockersys. Run the following command to check whether the container capacity has been expanded:
kubectl exec -it pod_name -- /bin/sh df -hIf the information similar to the following is displayed, the overlay capacity has been expanded from 10 GiB to 15 GiB.
Filesystem Size Used Avail Use% Mounted on overlay 15G 104K 15G 1% / tmpfs 64M 0 64M 0% /dev tmpfs 3.6G 0 3.6G 0% /sys/fs/cgroup /dev/mapper/vgpaas-share 98G 4.0G 89G 5% /etc/hosts ...
- Device Mapper: A thin pool is allocated to store image data. Run the following command to check whether the container capacity has been expanded:
kubectl exec -it pod_name -- /bin/sh df -hIf the information similar to the following is displayed, the thin pool capacity has been expanded from 10 GiB to 15 GiB.
Filesystem Size Used Avail Use% Mounted on /dev/mapper/vgpaas-thinpool-snap-84 15G 232M 15G 2% / tmpfs 64M 0 64M 0% /dev tmpfs 3.6G 0 3.6G 0% /sys/fs/cgroup /dev/mapper/vgpaas-kubernetes 11G 41M 11G 1% /etc/hosts /dev/mapper/vgpaas-dockersys 20G 1.1G 18G 6% /etc/hostname ...
