Help Center/ Cloud Container Engine/ FAQs/ Billing/ Can I Delete a Yearly/Monthly-Billed CCE Cluster Directly When It Expires?
Updated on 2026-01-05 GMT+08:00
After a yearly/monthly-billed cluster expires, you can delete the cluster after all data is backed up.
If you do not renew or delete the cluster after it expires, the system will delete the cluster. You are advised to renew the cluster and back up data in a timely manner.
