Help Center/ Cloud Container Engine/ FAQs/ Node/ Node Running/ How Do I Configure a Pod to Use the Acceleration Capability of a GPU Node?
Updated on 2025-03-26 GMT+08:00
Symptom
I have purchased a GPU node, but the operating speed is still slow. How do I configure the pod to use the acceleration capability of the GPU node?
Solution
Solution 1:
You are advised to remove the unschedulable taints from the GPU nodes in the cluster, so that the GPU plug-in driver can be properly installed. In addition, you need to install the GPU driver of a later version.
If a container is not deployed on a GPU node in your cluster, you can configure affinity and anti-affinity policies to prevent the container from being scheduled to the GPU node.
Solution 2:
You are advised to install the GPU driver of a later version and use kubectl to update the GPU plug-in configuration. Add the following configuration:
tolerations:
- operator: "Exists"
After the configuration is added, the GPU plug-in driver can be properly installed on the GPU node with a taint.
