Help Center/Cloud Container Engine/FAQs/Cluster/Cluster Running/Can I Directly Connect to the Master Node of a CCE Cluster?
Updated on 2024-07-04 GMT+08:00
CCE allows you to use kubectl to connect a cluster. For details, see Connecting to a Cluster Using kubectl.
However, you are not allowed to log in to the master node to perform related operations.
