Help Center/ Cloud Container Engine/ FAQs/ Node/ Node Running/ How Do I Log In to a Node Using a Password and Reset the Password?
Updated on 2025-07-17 GMT+08:00
Context
When creating a node on CCE, you selected a key pair or specified a password for login. If you forget your key pair or password, you can log in to the ECS console to reset the password of the node. After the password is reset, you can log in to the node using the password.
  1. Log in to the ECS console.
  2. In the ECS list, select the cloud server type of the node. In the same row as the node, choose More > Stop.
  3. After the node is stopped, choose More > Reset Password, and follow on-screen prompts to reset the password.
  4. After the password is reset, choose More > Start, and click Remote Login to log in to the node using the password.
