Help Center/ Cloud Container Engine/ FAQs/ Node/ Node Creation/ How Do I Troubleshoot Problems Occurred When Accepting Nodes into a CCE Cluster?
Updated on 2026-02-02 GMT+08:00
Overview
This section describes how to troubleshoot the problems occurred when you accept or add existing ECSs to a CCE cluster.
  • While an ECS is being accepted into a cluster, the operating system of the ECS will be reset to the standard OS image provided by CCE to ensure node stability. The CCE console prompts you to select the operating system and the login mode during the reset.
  • The ECS system and data disks will be formatted while the ECS is being accepted into a cluster. Ensure that data in the disks has been backed up.
  • During the acceptance of an ECS, do not perform any operation on the ECS through the ECS console.
Notes and Constraints
  • BMSs and ECSs, as well as DeHs can be managed.
The cloud servers to be managed must meet the following requirements:
  • The node to be accepted must be in the Running state and not used by other clusters. In addition, the node to be accepted does not carry the CCE-Dynamic-Provisioning-Node tag.
  • The node to be accepted and the cluster must be in the same VPC. (If the cluster version is earlier than v1.13.10, the node to be accepted and the CCE cluster must be in the same subnet.)
  • Data disks must be attached to the nodes to be managed if the system components of these nodes are stored separately. These nodes can be attached with either a local disk (disk-intensive disk) or a data disk of at least 20 GiB. Additionally, any data disks already attached must not be smaller than 10 GiB. For details about how to attach a data disk, see Adding a Disk to an ECS.
  • The node to be accepted must have at least 2 CPU cores, 4 GiB of memory, and only one network interface.
  • Only cloud servers with the same data disk configuration can be accepted in batches for management.
  • If IPv6 is enabled for a cluster, only nodes in a subnet with IPv6 enabled can be accepted and managed. If IPv6 is not enabled for the cluster, only nodes in a subnet without IPv6 enabled can be accepted.
  • CCE Turbo clusters require that each node supports supplementary network interfaces, or you will need to bind at least 16 network interfaces. For details about the node flavors, see the options provided on the console when you create a node.
  • Data disks that have been partitioned will be ignored during node management. Ensure that there is at least one unpartitioned data disk meeting the specifications attached to the node.
View the cluster log information to locate the failure cause and rectify the fault.
  1. Log in to the CCE console and click Operation Records above the cluster list to view operation records.
  2. Click the record of the Failed status to view error information.
  3. Rectify the fault based on the error information and accept the node into a cluster again.
Common Issues
If a node fails to be managed, a message will be displayed, indicating that the disk partitioning does not work:
Install config-prepare failed: exit status 1, output: [ Mon Jul 17 14:26:10 CST 2023 ] start install config-prepare\nNAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINT\nsda 8:0 0 40G 0 disk \n└─sda1 8:1 0 40G 0 part /\nsdb 8:16 0 100G 0 disk \n└─sdb1 8:17 0 100G 0 part
disk /dev/sda has been partition, will skip this device\nRaw disk /dev/sdb has been partition, will skip this device\nwarning: selector can not match any evs volume
To resolve this issue, attach an unpartitioned data disk of 20 GiB or higher to the node. After the node is managed, the unpartitioned data disk is used to store the container runtime and kubelet. Partitioned data disks are ignored and no operation is performed. You can perform operations on them as required.
