Help Center/ Cloud Container Engine/ FAQs/ Storage/ Can Data Be Restored If Underlying EVS Disks Are Deleted or Expired?
Updated on 2026-01-05 GMT+08:00
- If underlying EVS disks are deleted, you may encounter the following situations:
- If you have created snapshots for the PVCs, you can restore data using the snapshots. For details, see Using a Snapshot to Create a PVC.
- If you have enabled the EVS recycle bin, you can recover the EVS disks from the recycle bin. For details, see Recovering Disks from the Recycle Bin.
- If the above scenarios are not met, the data cannot be restored.
- If an underlying yearly/monthly EVS disk has expired, you may encounter the following situations:
- If the EVS disk is still in the retention period, you can renew the EVS disk to continue using it.
- If the EVS disk is released due to arrears, and a snapshot has been created for the PVC, you can restore data using the snapshot. For details, see Using a Snapshot to Create a PVC.
- If the EVS disk is released due to arrears and no snapshot has been created, the data cannot be restored.
