Help Center/ Cloud Container Engine/ FAQs/ Chart and Add-on/ Does CCE Support nginx-ingress?
Updated on 2026-02-02 GMT+08:00
Introduction to nginx-ingress
nginx-ingress is a popular ingress-controller. It functions as a reverse proxy to import external traffic to a cluster and expose Services in Kubernetes clusters to external systems. In Layer 7 load balancing (ingress), domain names are used to match Services. In this way, Services in a cluster can be accessed through domain names.
This chart is composed of ingress-controller and nginx.
Installation Method
You can install the nginx-ingress add-on on the Add-ons page on the CCE console and configure its parameters.
