Help Center/ Cloud Container Engine/ FAQs/ Workload/ Workload Exception Troubleshooting/ What Should I Do If a Workload Is Stopped Caused by Pod Deletion?
Updated on 2026-06-26 GMT+08:00
Symptom
A workload is in Stopped state.
Possible Cause
The metadata.enable field in the YAML file of the workload is false. As a result, the pod of the workload is deleted and the workload is in the stopped status.
Solution
Delete the enable field or set it to true.
