Help Center/ Cloud Container Engine/ FAQs/ Billing/ How Do I Change the Billing Mode of a CCE Cluster from Pay-per-Use to Yearly/Monthly?
Updated on 2026-06-26 GMT+08:00
Currently, clusters support pay-per-use and yearly/monthly billing modes. A pay-per-use cluster can be converted to a yearly/monthly-billed cluster.
Changing the Billing Mode of a Cluster
To change the billing mode of a cluster from pay-per-use to yearly/monthly, perform the following operations:
- Log in to the CCE console. In the navigation pane, choose Clusters.
- Locate the target cluster, click ... to view more operations on the cluster, and choose Change Billing Mode.
- On the page displayed, select the target cluster and click OK. You can also select the nodes whose billing modes you want to change. Figure 1 Changing the billing mode of a cluster to yearly/monthly
- Wait for the resource checks and the order generation, click OK to go to the Billing Center, and submit the order. Figure 2 Generating an order
- Select the resources whose billing modes are to be changed to yearly/monthly, set the required duration, enable auto-renew, and click Pay. Figure 3 Changing the billing mode from pay-per-use to yearly/monthly
