Help Center/ Cloud Container Engine_Autopilot/ FAQs/ Namespace/ How Do I Delete a Namespace in the Terminating State?
Updated on 2025-09-02 GMT+08:00
A Kubernetes namespace is typically in the active or terminating state. If a namespace is deleted when there are still running resources, the namespace enters the terminating state. In this case, the namespace will be automatically deleted only after Kubernetes reclaims the resources in it.
However, in some cases, even if no resource is running in the namespace, the namespace in the terminating state still cannot be deleted.
To solve this problem, perform the following operations:
  1. View the namespace details.
    $ kubectl  get ns  | grep rdb
    rdbms                  Terminating   6d21h
    $ kubectl  get ns rdbms -o yaml
    apiVersion: v1
    kind: Namespace
      annotations:
        kubectl.kubernetes.io/last-applied-configuration: |
          {"apiVersion":"v1","kind":"Namespace","metadata":{"annotations":{},"name":"rdbms"}}
      creationTimestamp: "2020-05-07T15:19:43Z"
      deletionTimestamp: "2020-05-07T15:33:23Z"
      resourceVersion: "84553454"
      selfLink: /api/v1/namespaces/rdbms
      uid: 457788ddf-53d7-4hde-afa3-1fertg21ewe1
      finalizers:
      - kubernetes
    status:
      phase: Terminating
  2. View resources in the namespace.
    # View resources that can be isolated using namespaces in the cluster.
    $ kubectl api-resources -o name --verbs=list --namespaced | xargs -n 1 kubectl get --show-kind --ignore-not-found -n rdbms
    The command output shows that no resource is occupied in the rdbms namespace.
  3. Delete the namespace.
    Directly delete the rdbms namespace.
    $ kubectl  delete ns rdbms
    Error from server (Conflict): Operation cannot be fulfilled on namespaces "rdbms": The system is ensuring all content is removed from this namespace.  Upon completion, this namespace will automatically be purged by the system.
    The deletion fails and a message is displayed, indicating that the system will automatically delete the namespace after confirming that no resource is running in it.
  4. Forcibly delete the namespace.
    $ kubectl  delete ns rdbms --force --grace-period=0
    warning: Immediate deletion does not wait for confirmation that the running resource has been terminated. The resource may continue to run on the cluster indefinitely.
    After running this command, the namespace still cannot be deleted.
  5. Call the Kubernetes native APIs to delete resources in the namespace. In most cases, resources in a namespace cannot be forcibly deleted. Use the Kubernetes native APIs instead.
    $ kubectl  get ns rdbms  -o json > rdbms.json
    Check the JSON configuration defined by the namespace, edit the JSON file, and delete the spec part.
    $ cat rdbms.json
        "apiVersion": "v1",
        "kind": "Namespace",
        "metadata": {
            "annotations": {
                "kubectl.kubernetes.io/last-applied-configuration": "{\"apiVersion\":\"v1\",\"kind\":\"Namespace\",\"metadata\":{\"annotations\":{},\"name\":\"rdbms\"}}\n"
            "creationTimestamp": "2019-10-14T12:17:44Z",
            "deletionTimestamp": "2019-10-14T12:30:27Z",
            "name": "rdbms",
            "resourceVersion": "8844754",
            "selfLink": "/api/v1/namespaces/rdbms",
            "uid": "29067ddf-56d7-4cce-afa3-1fbdbb221ab1"
        "spec": {
            "finalizers": [
                "kubernetes"
        "status": {
            "phase": "Terminating"
    After the PUT request is executed, the namespace is automatically deleted.
    $ curl --cacert /root/ca.crt --cert /root/client.crt --key /root/client.key -k -H "Content-Type:application/json" -X PUT --data-binary @rdbms.json https://x.x.x.x:5443/api/v1/namespaces/rdbms/finalize
      "apiVersion": "v1",
      "metadata": {
        "name": "rdbms",
        "selfLink": "/api/v1/namespaces/rdbms/finalize",
        "uid": "29067ddf-56d7-4cce-afa3-1fbdbb221ab1",
        "annotations": {
      "spec": {
      "status": {
    If the namespace still cannot be deleted, check whether the finalizers field exists in the metadata. If the field exists, run the following command to access the namespace and delete the field:
    kubectl edit ns rdbms
    • For details about how to obtain a cluster certificate, see Accessing a Cluster Using an X.509 Certificate.
    • https://x.x.x.x:5443 indicates the address for accessing the cluster. To obtain the private IP address, log in to the CCE console, access the cluster console, and view the connection information.
  6. Check whether the namespace has been deleted.
