- Function Overview
- Product Bulletin
- Billing
- Getting Started
User Guide
- Clusters
- Workloads
- Network
- Storage
- O&M
- Namespaces
- ConfigMaps and Secrets
- Auto Scaling
- Add-ons
- Helm Chart
- Permissions
- Settings
- Best Practices
API Reference
- Before You Start
- API Overview
- Calling APIs
APIs
- Autopilot Cluster Management
- Add-on Management for Autopilot Clusters
Autopilot Cluster Upgrade
- Upgrading a Cluster
- Performing a Pre-upgrade Check for a Cluster
- Performing a Post-upgrade Check for a Cluster
- Backing Up a Cluster
- Obtaining Details About a Specified Cluster Upgrade Booting Task
- Quota Management for Autopilot Clusters
- Tag Management for Autopilot Clusters
Chart Management for Autopilot Clusters
- Uploading a Chart
- Obtaining a Chart List
- Obtaining a Release List
- Creating a Release
- Updating a Chart
- Deleting a Chart
- Updating a Release
- Obtaining a Chart
- Deleting a Release
- Downloading a Chart
- Obtaining Chart Values
- Kubernetes APIs
- Appendix
- Billing
- Workloads
- Network Management
- Can PVs of the EVS Type in a CCE Autopilot Cluster Be Restored After They Are Deleted or Expire?
- Can CCE Autopilot PVCs Detect Underlying Storage Faults?
- How Can I Delete the Underlying Storage If It Remains After a Dynamically Created PVC is Deleted?
- Permissions
How Do I Configure Security Group Rules for a Cluster?
When a CCE Autopilot cluster is created, two security groups are automatically created, one for master nodes, and the other for elastic network interfaces (ENIs). The security group for master nodes is named in the format of {Cluster name}-cce-control-{Random ID}, and that for ENIs is in the format of {Cluster name}-cce-eni-{Random ID}.
You can modify the security group rules on the VPC console as required. (Log in to the management console, choose Service List > Networking > Virtual Private Cloud. On the page displayed, choose Access Control > Security Groups in the navigation pane, locate the target security groups, and modify their rules.)
- Modifying or deleting default rules in a security group may affect cluster running. If you need to modify security group rules, do not modify the rules of the port that CCE running depends on.
- When adding a security group rule, ensure that this rule does not conflict with the existing rules. If there is a conflict, existing rules may become invalid, affecting cluster running.
Security Group for Master Nodes
The security group automatically created for master nodes is named {Cluster name}-cce-control-{Random ID}. Table 1 lists the default ports in the security group.
Direction |
Port |
Source |
Description |
Modifiable |
Modification Suggestion |
Inbound |
All |
IP addresses of this security group |
Allow traffic from all IP addresses in this security group |
No |
None |
Outbound |
All |
All IP addresses: 0.0.0.0/0 or ::/0 |
Allow traffic on all ports by default. |
No |
None |
Security Group for ENIs
When a CCE Autopilot cluster is created, a security group named {Cluster name}-cce-eni-{Random ID} is automatically created for ENIs. By default, pods in the cluster are associated with this security group. Table 2 lists the default ports in the security group.
Direction |
Port |
Source |
Description |
Modifiable |
Inbound |
All |
No |
None |
CIDR block of the master nodes |
Allow the master nodes to access kubelet on each worker node, for example, by running kubectl exec {Pod}. |
No |
None |
Outbound |
All |
Yes |
If you want to harden security by allowing traffic over specific ports, you can modify the rule to allow these ports. For details, see Hardening Outbound Rules for the Security Group of ENIs. |
By default, all ENI security groups created by CCE Autopilot allow all outbound traffic. You are advised to retain this configuration. If you want to harden security by allowing traffic over specific ports, configure the ports listed in the following table.
Port |
Allowed CIDR Block |
Description |
All |
Allow mutual access within the security group so containers can communicate with each other. |
TCP port 5443 |
VPC CIDR block |
Allow access from kube-apiserver, which provides lifecycle management for Kubernetes resources. |
TCP port 443 |
100.125.0.0/16 |
Access the OBS port or SWR port to pull images. |
UDP port 53 |
100.125.0.0/16 |
Allow traffic over the port for DNS resolution. |
TCP port 443 |
VPC CIDR block |
Pull the images through the SWR endpoint. |
All |
198.19.128.0/17 |
Allow worker nodes to access the VPC Endpoint (VPCEP) service. |
TCP port 9443 |
VPC CIDR block |
Allow the network add-ons of the worker nodes to access master nodes. |
