- Function Overview
- Product Bulletin
- Billing
- Getting Started
User Guide
- Clusters
- Workloads
- Network
- Storage
- O&M
- Namespaces
- ConfigMaps and Secrets
- Auto Scaling
- Add-ons
- Helm Chart
- Permissions
- Settings
- Best Practices
API Reference
- Before You Start
- API Overview
- Calling APIs
APIs
- Autopilot Cluster Management
- Add-on Management for Autopilot Clusters
Autopilot Cluster Upgrade
- Upgrading a Cluster
- Performing a Pre-upgrade Check for a Cluster
- Performing a Post-upgrade Check for a Cluster
- Backing Up a Cluster
- Obtaining Details About a Specified Cluster Upgrade Booting Task
- Quota Management for Autopilot Clusters
- Tag Management for Autopilot Clusters
Chart Management for Autopilot Clusters
- Uploading a Chart
- Obtaining a Chart List
- Obtaining a Release List
- Creating a Release
- Updating a Chart
- Deleting a Chart
- Updating a Release
- Obtaining a Chart
- Deleting a Release
- Downloading a Chart
- Obtaining Chart Values
- Kubernetes APIs
- Appendix
- Billing
- Workloads
- Network Management
- Can PVs of the EVS Type in a CCE Autopilot Cluster Be Restored After They Are Deleted or Expire?
- Can CCE Autopilot PVCs Detect Underlying Storage Faults?
- How Can I Delete the Underlying Storage If It Remains After a Dynamically Created PVC is Deleted?
- Permissions
Show all
How Is a CCE Autopilot Cluster Billed?
Billing Modes
CCE Autopilot supports two billing modes: pay-per-use and packages.
- Pay-per-use: You can start using CCE Autopilot resources first and then pay as you go. Their usage durations are calculated by the second but billed every hour. This allows you to flexibly adjust the resources. You neither need to prepare for resources in advance, nor end up with excessive or insufficient preset resources. Pay-per-use billing is a good option for scenarios where there are sudden traffic bursts, such as e-commerce promotions.
- Packages: You need to pay for packages before using them. Their usages are settled every hour. You can buy packages to save money. Packages are a good option for long-term, stable services.
On the Overview page of the cluster console, you can purchase CPU and/or memory packages required by pods. After you purchase a package in a region, it can be used by all pods in all CCE Autopilot clusters in that region.
There are no packages for the cluster management and VPC endpoints required by CCE Autopilot clusters. Also, packages are unavailable for other cloud service resources on the CCE console. When a cloud service resource is created on the CCE console, it is billed on a pay-per-use basis by default. You can go to the corresponding cloud service console to purchase yearly/monthly cloud service resources or packages. These resources or packages will be billed based on their standard prices.
Billing Mode |
Pay-per-use |
Package |
Payment |
Postpaid. You are billed based on the actual usage durations. |
Prepaid. The packages are used first during the subscription period. |
Billing Method |
Calculated by the second but billed every hour |
Billed by the subscription term you purchase |
Billing Items |
All billed items |
Only vCPU and memory required by the pods |
Application Scenario |
Recommended when the resource demands are likely to fluctuate and you want more flexibility |
A cost-effective option for scenarios where the resource usage duration is predictable. It is recommended for resources expected to be used for a long term. |
Billed Items
The total expenditures generated when you use a CCE Autopilot consist of the cluster management, pods, VPC endpoints, and other cloud service resources. For details, see "Billed Items" in "Billing" in the User Guide.
