Version Planning
This section describes the version support of the SparkRTC client SDK.
Version Description
The version number is in the format of a.b.c.d, where:
- a indicates the major version number, which is updated when the version architecture is reconstructed.
- b indicates the minor version number, which is updated in the case of major feature or API changes.
- c indicates the monthly development version number, whose value is incremented by 1 every month.
- d indicates the release version number. The value starting with 300 indicates the first release version number, whose value is incremented as a new patch version is released.
Example version number: 2.0.9.300
Version Lifecycle
By default, a major version is released every two to three months, or a version is modified based on customer requirements.
Version Constraints
None. The old and new versions are compatible.
