Updated on 2025-12-17 GMT+08:00
Gatekeeper Release History
CCE regularly updates the Gatekeeper add-on to enhance features, optimize performance, and fix bugs, ultimately improving user experience and system stability. It is recommended that you upgrade the add-on to the latest version periodically to access new functions, avoid vulnerabilities, and maintain service security and reliability.
Table 1 Gatekeeper add-on
Add-on Version
Supported Cluster Version
New Feature
Community Version
1.1.3
v1.27
v1.28
v1.29
v1.30
v1.31
v1.32
v1.33
  • CCE clusters v1.33 are supported.
  • The community version is upgraded to v3.19.3.
3.19.3
1.0.32
v1.25
v1.27
v1.28
v1.29
v1.30
v1.31
v1.32
CCE clusters v1.32 are supported.
3.16.3
1.0.23
v1.25
v1.27
v1.28
v1.29
v1.30
v1.31
Fixed some issues.
3.16.3
1.0.22
v1.25
v1.27
v1.28
v1.29
v1.30
v1.31
CCE clusters v1.31 are supported.
3.16.3
1.0.10
v1.23
v1.25
v1.27
v1.28
v1.29
v1.30
CCE clusters v1.30 are supported.
3.16.3
1.0.3
v1.23
v1.25
v1.27
v1.28
v1.29
The Gatekeeper add-on is now available.
3.16.3
