OpenKruise Release History
CCE regularly updates the OpenKruise add-on to enhance features, optimize performance, and address bugs, ultimately improving user experience and system stability. It is recommended that you upgrade the add-on to the latest version periodically to access new functions, avoid vulnerabilities, and maintain service security and reliability.
Add-on Version |
Supported Cluster Version |
New Feature |
Community Version |
1.0.35 |
v1.25 v1.27 v1.28 v1.29 v1.30 v1.31 v1.32 |
CCE clusters v1.32 are supported. |
1.0.23 |
v1.25 v1.27 v1.28 v1.29 v1.30 v1.31 |
CCE clusters v1.31 are supported. |
1.0.12 |
v1.23 v1.25 v1.27 v1.28 v1.29 v1.30 |
CCE clusters v1.30 are supported. |
1.0.3 |
v1.23 v1.25 v1.27 v1.28 v1.29 |
The OpenKruise add-on is now available. |
