Help Center/ Cloud Container Engine/ Product Bulletin/ Product Release Notes/ Add-on Versions/ Cloud Native Cluster Monitoring Release History
Updated on 2025-07-15 GMT+08:00
CCE regularly updates the Cloud Native Cluster Monitoring add-on to enhance features, optimize performance, and fix bugs, ultimately improving user experience and system stability. It is recommended that you upgrade the add-on to the latest version periodically to access new functions, avoid vulnerabilities, and maintain service security and reliability.
Table 1 Release history
Add-on Version
Supported Cluster Version
New Feature
Community Version
3.12.1
v1.21
v1.23
v1.25
v1.27
v1.28
v1.29
v1.30
v1.31
v1.32
CCE clusters v1.32 are supported.
2.53.2
3.12.0
v1.21
v1.23
v1.25
v1.27
v1.28
v1.29
v1.30
v1.31
  • CCE clusters v1.31 are supported.
  • Upgraded Prometheus.
2.53.2
3.11.0
v1.21
v1.23
v1.25
v1.27
v1.28
v1.29
v1.30
CCE clusters v1.30 are supported.
2.37.8
3.10.1
v1.21
v1.23
v1.25
v1.27
v1.28
v1.29
The NodeExporter component is upgraded to 1.8.0.
2.37.8
3.10.0
v1.21
v1.23
v1.25
v1.27
v1.28
v1.29
Clusters v1.29 are supported.
2.37.8
3.9.5
v1.21
v1.23
v1.25
v1.27
v1.28
  • Added the option for collecting custom metrics. This function is enabled by default.
  • Removed support for clusters 1.17 and 1.19.
  • Removed Grafana. Grafana is split into an independent add-on.
  • Collected only free metrics and custom service discovery metrics by default.
  • Upgraded the open-source components.
2.37.8
3.8.2
v1.17
v1.19
v1.21
v1.23
v1.25
v1.27
Fixed some issues.
2.35.0
3.7.3
v1.17
v1.19
v1.21
v1.23
v1.25
None
2.35.0
3.7.2
v1.17
v1.19
v1.21
v1.23
v1.25
Supported collection of Virtual Kubelet pod metrics.
2.35.0
3.7.1
v1.17
v1.19
v1.21
v1.23
v1.25
Supports PrometheusAgent.
2.35.0
3.6.6
v1.17
v1.19
v1.21
v1.23
v1.25
  • Grafana is upgraded to 7.5.17.
  • Supported containerd nodes.
2.35.0
3.5.1
v1.17
v1.19
v1.21
v1.23
None
2.35.0
3.5.0
v1.17
v1.19
v1.21
v1.23
Updated the add-on to its community version v2.35.0.
2.35.0
