CCE Secrets Manager for DEW Release History
CCE regularly updates the CCE Secrets Manager for DEW add-on to enhance features, optimize performance, and fix bugs, ultimately improving user experience and system stability. It is recommended that you upgrade the add-on to the latest version periodically to access new functions, avoid vulnerabilities, and maintain service security and reliability.
Add-on Version |
Supported Cluster Version |
New Feature |
1.1.82 |
v1.27 v1.28 v1.29 v1.30 v1.31 v1.32 v1.33 |
Fixed some issues. |
1.1.81 |
CCE clusters v1.33 are supported. |
1.1.75 |
v1.25 v1.27 v1.28 v1.29 v1.30 v1.31 v1.32 |
CCE clusters v1.32 are supported. |
1.1.60 |
v1.25 v1.27 v1.28 v1.29 v1.30 v1.31 |
1.1.57 |
CCE clusters v1.31 are supported. |
1.1.33 |
v1.21 v1.23 v1.25 v1.27 v1.28 v1.29 v1.30 |
CCE clusters v1.30 are supported. |
1.1.3 |
v1.21 v1.23 v1.25 v1.27 v1.28 v1.29 |
1.1.2 |
1.0.31 |
v1.21 v1.23 v1.25 v1.27 v1.28 |
1.0.9 |
v1.19 v1.21 v1.23 v1.25 |
None |
1.0.6 |
None |
1.0.3 |
CCE clusters v1.25 are supported. |
1.0.2 |
v1.19 v1.21 v1.23 |
CCE clusters v1.23 are supported. |
1.0.1 |
v1.19 v1.21 |
Supported active detection of changes on the SecretProviderClass objects. |
