Updated on 2025-11-07 GMT+08:00
CCE AI Suite (Ascend NPU) Release History
CCE regularly updates the CCE AI Suite (Ascend NPU) add-on to enhance features, optimize performance, and fix bugs, ultimately improving user experience and system stability. It is recommended that you upgrade the add-on to the latest version periodically to access new functions, avoid vulnerabilities, and maintain service security and reliability.
Table 1 CCE AI Suite (Ascend NPU) add-on
Add-on Version
Supported Cluster Version
New Feature
2.3.2
v1.27
v1.28
v1.29
v1.30
v1.31
v1.32
v1.33
Added image signature.
2.2.2
v1.27
v1.28
v1.29
v1.30
v1.31
v1.32
v1.33
CCE clusters v1.33 are supported.
2.1.63
v1.25
v1.27
v1.28
v1.29
v1.30
v1.31
v1.32
CCE clusters v1.32 are supported.
2.1.53
v1.25
v1.27
v1.28
v1.29
v1.30
v1.31
Fixed the security vulnerabilities.
2.1.46
v1.21
v1.23
v1.25
v1.27
v1.28
v1.29
v1.30
v1.31
CCE clusters v1.31 are supported.
2.1.23
v1.21
v1.23
v1.25
v1.27
v1.28
v1.29
v1.30
Fixed some issues.
2.1.22
v1.21
v1.23
v1.25
v1.27
v1.28
v1.29
v1.30
  • Fixed display issues on some pages.
  • Hypernodes can be obtained.
  • NPU topology can be reported.
  • Resolved log printing issues.
2.1.14
v1.21
v1.23
v1.25
v1.27
v1.28
v1.29
v1.30
Fixed some issues.
2.1.7
v1.21
v1.23
v1.25
v1.27
v1.28
v1.29
Resolved the issue that npu-smi fails to be automatically mounted to a service container.
2.1.5
v1.21
v1.23
v1.25
v1.27
v1.28
v1.29
  • CCE clusters v1.29 are supported.
  • Added silent fault codes.
2.0.9
v1.21
v1.23
v1.25
v1.27
v1.28
Fixed the issue that process-level fault recovery and annotation adding to workloads occasionally fail.
2.0.5
v1.21
v1.23
v1.25
v1.27
v1.28
  • CCE clusters v1.28 are supported.
  • Supported liveness probes.
  • Ascend drivers can be automatically mounted to service containers.
1.2.14
v1.19
v1.21
v1.23
v1.25
v1.27
Supported NPU monitoring.
1.2.6
v1.19
v1.21
v1.23
v1.25
Supported automatic installation of NPU drivers.
1.2.5
v1.19
v1.21
v1.23
v1.25
1.2.4
v1.19
v1.21
v1.23
v1.25
CCE clusters v1.25 are supported.
1.2.2
v1.19
v1.21
v1.23
CCE clusters v1.23 are supported.
1.2.1
v1.19
v1.21
v1.23
1.1.8
v1.15
v1.17
v1.19
v1.21
CCE clusters v1.21 are supported.
1.1.2
v1.15
v1.17
v1.19
Added the default seccomp profile.
1.1.1
v1.15
v1.17
v1.19
CCE clusters v1.15 are supported.
1.1.0
v1.17
v1.19
CCE clusters v1.19 are supported.
1.0.8
v1.13
v1.15
v1.17
Adapted to the Snt3 C75 drivers.
1.0.6
v1.13
v1.15
v1.17
Supported the C75 drivers.
1.0.5
v1.13
v1.15
v1.17
Allowed containers to use Huawei NPUs.
1.0.3
v1.13
v1.15
v1.17
