Updated on 2025-12-17 GMT+08:00
CCE AI Suite (NVIDIA GPU) Release History
CCE regularly updates the CCE AI Suite (NVIDIA GPU) add-on to enhance features, optimize performance, and fix bugs, ultimately improving user experience and system stability. It is recommended that you upgrade the add-on to the latest version periodically to access new functions, avoid vulnerabilities, and maintain service security and reliability.
Table 1 CCE AI Suite (NVIDIA GPU) add-on
Add-on Version
Supported Cluster Version
New Feature
2.10.3
v1.28
v1.29
v1.30
v1.31
v1.32
v1.33
Fixed some issues.
2.10.2
v1.28
v1.29
v1.30
v1.31
v1.32
v1.33
Supported NVIDIA driver 570.86.15.
2.8.4
v1.28
v1.29
v1.30
v1.31
v1.32
Fixed CVE-2025-23266 and CVE-2025-23267.
2.8.1
v1.28
v1.29
v1.30
v1.31
v1.32
Fixed some issues.
2.7.84
v1.28
v1.29
v1.30
v1.31
v1.32
CCE clusters v1.32 are supported.
2.7.66
v1.28
v1.29
v1.30
v1.31
Fixed some issues.
2.7.63
v1.28
v1.29
v1.30
v1.31
Fixed the security vulnerabilities.
2.7.47
v1.28
v1.29
v1.30
v1.31
Added the NVIDIA 535.216.03 drivers that support xGPUs.
2.7.42
v1.28
v1.29
v1.30
v1.31
2.7.41
v1.28
v1.29
v1.30
v1.31
2.7.40
v1.28
v1.29
v1.30
v1.31
Integrated with DCGM-Exporter to observe the DCGM metrics of NVIDIA GPU nodes in clusters.
2.7.19
v1.28
v1.29
v1.30
Fixed the nvidia-container-toolkit CVE-2024-0132 container escape vulnerability.
2.7.13
v1.28
v1.29
v1.30
  • Supported xGPU configuration by node pool.
  • Supported GPU rendering.
  • Clusters v1.30 are supported.
2.6.4
v1.28
v1.29
Updated the isolation logic of GPU cards.
2.6.1
v1.28
v1.29
Upgraded the base images of the add-on.
2.5.6
v1.28
Fixed an issue that occurred during the installation of the driver.
2.5.4
v1.28
Clusters v1.28 are supported.
2.2.4
v1.25
v1.27
2.2.1
v1.25
v1.27
Fixed some issues.
2.1.67
v1.25
v1.27
Supported the nvidia-peermem module.
2.1.49
v1.25
v1.27
2.1.47
v1.25
v1.27
2.1.26
v1.21
v1.23
v1.25
v1.27
2.1.14
v1.21
v1.23
v1.25
v1.27
2.1.8
v1.21
v1.23
v1.25
v1.27
Fixed some issues.
2.0.69
v1.21
v1.23
v1.25
v1.27
2.0.46
v1.21
v1.23
v1.25
v1.27
  • Supported NVIDIA driver 535.
  • Non-root users can use xGPUs.
  • Optimized startup logic.
2.0.18
v1.21
v1.23
v1.25
v1.27
Supported Huawei Cloud EulerOS 2.0.
1.2.28
v1.19
v1.21
v1.23
v1.25
  • Adapted to Ubuntu 22.04.
  • Optimized the automatic mounting of the GPU driver directory.
1.2.24
v1.19
v1.21
v1.23
v1.25
  • Enabled a node pool to configure GPU driver versions.
  • Supported GPU metric collection.
1.2.20
v1.19
v1.21
v1.23
v1.25
Set the add-on alias to gpu.
1.2.17
v1.15
v1.17
v1.19
v1.21
v1.23
Added the nvidia-driver-install pod limit configuration.
1.2.15
v1.15
v1.17
v1.19
v1.21
v1.23
CCE clusters v1.23 are supported.
1.2.11
v1.15
v1.17
v1.19
v1.21
Supported EulerOS 2.10.
1.2.10
v1.15
v1.17
v1.19
v1.21
CentOS supports the GPU driver of the new version.
1.2.9
v1.15
v1.17
v1.19
v1.21
CCE clusters v1.21 are supported.
1.2.2
v1.15
v1.17
v1.19
Supported the new EulerOS kernel.
1.2.1
v1.15
v1.17
v1.19
  • CCE clusters v1.19 are supported.
  • Added taints and tolerations.
1.1.13
v1.13
v1.15
v1.17
Supported kernel-3.10.0-1127.19.1.el7.x86_64 for CentOS 7.6.
1.1.11
v1.15
v1.17
  • Allowed users to customize driver addresses to download drivers.
  • Clusters v1.15 and v1.17 are supported.
