Updated on 2025-07-15 GMT+08:00
Kubernetes Dashboard Release History
CCE regularly updates the Kubernetes Dashboard add-on to enhance features, optimize performance, and address bugs, ultimately improving user experience and system stability. It is recommended that you upgrade the add-on to the latest version periodically to access new functions, avoid vulnerabilities, and maintain service security and reliability.
Table 1 Release history
Add-on Version
Supported Cluster Version
New Feature
Community Version
4.0.13
v1.30
v1.31
v1.32
CCE clusters v1.32 are supported.
7.10.0
4.0.1
v1.30
v1.31
  • CCE clusters v1.31 are supported.
  • Updated the add-on to its community version v7.10.0.
7.10.0
3.0.25
v1.27
v1.28
v1.29
Fixed some issues.
7.3.2
3.0.4
v1.27
v1.28
v1.29
Fixed some issues.
7.3.2
3.0.2
v1.27
v1.28
v1.29
  • Supported clusters of v1.27, v1.28, and v1.29.
  • Updated the add-on to its community version v7.3.2.
7.3.2
2.2.27
v1.21
v1.23
v1.25
Fixed some issues.
2.7.0
2.2.7
v1.21
v1.23
v1.25
None
2.7.0
2.2.5
v1.21
v1.23
v1.25
Synchronized time zones used by the add-on and the node.
2.7.0
2.2.3
v1.21
v1.23
v1.25
None
2.7.0
2.1.1
v1.19
v1.21
v1.23
  • CCE clusters v1.23 are supported.
  • Updated the add-on to its community version v2.5.0.
2.5.0
2.0.10
v1.15
v1.17
v1.19
v1.21
CCE clusters v1.21 are supported.
2.0.0
2.0.4
v1.15
v1.17
v1.19
Added the default seccomp profile.
2.0.0
2.0.3
v1.15
v1.17
v1.19
CCE clusters v1.15 are supported.
2.0.0
2.0.2
v1.17
v1.19
CCE clusters v1.19 are supported.
2.0.0
2.0.1
v1.15
v1.17
2.0.0
2.0.0
v1.17
Enabled interconnection with CCE v1.17
2.0.0
