CCE Node Problem Detector Release History
CCE regularly updates the CCE Node Problem Detector add-on to enhance features, optimize performance, and fix bugs, ultimately improving user experience and system stability. It is recommended that you upgrade the add-on to the latest version periodically to access new functions, avoid vulnerabilities, and maintain service security and reliability.
Add-on Version |
Supported Cluster Version |
New Feature |
Community Version |
1.19.25 |
v1.25 v1.27 v1.28 v1.29 v1.30 v1.31 v1.32 |
CCE clusters v1.32 are supported. |
1.19.20 |
v1.25 v1.27 v1.28 v1.29 v1.30 v1.31 |
Fixed some issues. |
1.19.16 |
v1.21 v1.23 v1.25 v1.27 v1.28 v1.29 v1.30 v1.31 |
CCE clusters v1.31 are supported. |
1.19.11 |
v1.21 v1.23 v1.25 v1.27 v1.28 v1.29 v1.30 |
1.19.8 |
1.19.1 |
v1.21 v1.23 v1.25 v1.27 v1.28 v1.29 |
1.19.0 |
v1.21 v1.23 v1.25 v1.27 v1.28 |
1.18.48 |
1.18.46 |
CCE clusters v1.28 are supported. |
1.18.22 |
v1.19 v1.21 v1.23 v1.25 v1.27 |
None |
1.18.14 |
v1.19 v1.21 v1.23 v1.25 |
1.18.10 |
1.17.4 |
v1.17 v1.19 v1.21 v1.23 v1.25 |
Optimized DiskHung check item. |
1.17.3 |
1.17.2 |
1.16.4 |
v1.17 v1.19 v1.21 v1.23 |
1.16.3 |
Added the function of checking the ResolvConf configuration file. |
1.16.1 |
1.15.0 |
1.14.11 |
v1.17 v1.19 v1.21 |
CCE clusters v1.21 are supported. |
1.14.5 |
v1.17 v1.19 |
Fixed the issue that monitoring metrics cannot be obtained. |
1.14.4 |
v1.17 v1.19 |
1.14.2 |
v1.17 v1.19 |
1.13.8 |
v1.15.11 v1.17 |
1.13.6 |
v1.15.11 v1.17 |
Fixed the issue that zombie processes are not reclaimed. |
1.13.5 |
v1.15.11 v1.17 |
Added taint tolerance configuration. |
1.13.2 |
v1.15.11 v1.17 |
Added resource limits and enhanced the detection capability of the cni add-on. |
