Updated on 2025-07-15 GMT+08:00
Kubernetes Version Policy
CCE provides highly scalable, high-performance, enterprise-class Kubernetes clusters. As the Kubernetes community periodically releases Kubernetes versions, CCE will release cluster Open Beta Test (OBT) and commercially used versions accordingly. This section describes the Kubernetes version policy of CCE clusters.
Lifecycle of CCE Cluster Versions
Kubernetes Version
Status
Community Release In
OBT of CCE Clusters
Commercial Use of CCE Clusters
EOS of CCE Clusters
v1.32
OBT
August 2024
July 2025
v1.31
In commercial usea
August 2024
January 2025
April 2025
April 2027
v1.30
In commercial usea
April 2024
September 2024
October 2024
October 2026
v1.29
In commercial usea
November 2023
April 2024
June 2024
June 2026
v1.28
In commercial useb
August 2023
December 2023
February 2024
February 2026
v1.27
In commercial useb
April 2023
August 2023
October 2023
October 2025
v1.25
EOS
August 2022
November 2022
March 2023
March 2025
v1.23
EOS
December 2021
April 2022
September 2022
September 2024
v1.21
End of service (EOS)
April 2021
December 2021
April 2022
April 2024
v1.19
EOS
August 2020
December 2020
March 2021
September 2023
v1.17
EOS
December 2019
July 2020
January 2023
v1.15
EOS
June 2019
December 2019
September 2022
v1.13
EOS
December 2018
June 2019
March 2022
v1.11
EOS
August 2018
October 2018
March 2021
v1.9
EOS
December 2017
March 2018
December 2020
  • a: Clusters created using the console or APIs
  • b: Clusters created only using APIs
Phases of CCE Cluster Versions
  • OBT: You can experience the latest features of this cluster version. However, the stability of clusters of this version has not been completely verified, and the Service Level Agreement (SLA) of CCE is not valid for such clusters.
  • In commercial use: The cluster version has been fully verified and is stable and reliable. You can use clusters of this version in the production environment, and the CCE SLA is valid for such clusters.
  • EOS: After the cluster version EOS, CCE does not support the creation of new clusters or provide technical support including new feature updates, vulnerability or issue fixes, new patches, service ticket guidance, and online checks for the EOS cluster version. The CCE SLA is not valid for such clusters.
CCE clusters are updated according to the versions available in the Kubernetes community. This means that a CCE cluster version is made up of both the Kubernetes community version number and the CCE patch version number. The CCE cluster version is in the format of vX.Y.Z-rN, for example, v1.28.2-r0.
  • A Kubernetes version is in the format of X.Y.Z, which inherits the community version policy. The major Kubernetes version is represented by X, the minor Kubernetes version is represented by Y, and the Kubernetes patch version is represented by Z. For details, see the Kubernetes version policies. For details about the Kubernetes versions supported by CCE, see Kubernetes Version Release Notes.
  • A CCE patch version is in the format of, for example, v1.30.4-rN. New patches are released on an irregular basis for Kubernetes versions that are still in the maintenance period. If a new patch version provides new features, bug fixes, vulnerability fixes, or scenario optimizations compared with the previous version, the N version number increases. For details about CCE patch versions, see Patch Versions.
Cluster Upgrade
Periodically upgrade CCE clusters for better user experience. Using an EOS version, you cannot obtain technical support and CCE SLA assurance. Upgrade CCE clusters in a timely manner.
On the CCE console, you can easily upgrade clusters in a visualized manner, improving the stability and reliability of clusters.
