OS Version Support Mechanism
Synchronization Mechanism
CCE cluster node components are updated with the release of CCE cluster versions.
Major OS vulnerability fixing: The policy for fixing major OS vulnerabilities is released with the cluster patch upgrade policy.
Mappings Between Cluster Versions and OS Versions
The following table lists the mappings between released cluster versions and OS versions.
OS |
Cluster Version |
CCE Standard Cluster |
CCE Turbo Cluster |
Latest Kernel |
VPC Network |
Tunnel Network |
Cloud Native Network 2.0 |
Huawei Cloud EulerOS 2.0 |
v1.32 |
5.10.0-182.0.0.95.r2673_211.hce2.x86_64 |
v1.31 |
v1.30 |
v1.29 |
v1.28 |
v1.27 |
Supported in v1.27.3-r0 or later. |
v1.25 (end of maintenance) |
Supported in v1.25.6-r0 or later. |
v1.23 (end of maintenance) |
Supported in v1.23.11-r0 or later. |
Huawei Cloud EulerOS 2.0 (Arm) |
v1.32 |
5.10.0-182.0.0.95.r2673_211.hce2.aarch64 |
v1.31 |
v1.30 |
v1.29 |
v1.28 |
v1.27 |
Supported in v1.25.3-r0 or later. |
Supported in v1.23.6-r0 or later. |
Ubuntu 22.04 |
v1.32 |
5.15.0-138-generic |
v1.31 |
v1.30 |
v1.29 |
v1.28 |
v1.27 |
Supported in v1.23.8-r0 or later. |
Huawei Cloud EulerOS 1.1 |
v1.32 |
3.10.0-1160.76.2.hce1c.x86_64 |
v1.31 |
v1.30 |
v1.29 |
v1.28 |
v1.27 |
v1.21 (end of maintenance) |
EulerOS release 2.9 |
v1.32 |
4.18.0-147.5.1.6.h1511.eulerosv2r9.x86_64 |
v1.31 |
v1.30 |
v1.29 |
v1.28 |
v1.27 |
v1.19 (end of maintenance) |
4.18.0-147.5.1.6.h1152.eulerosv2r9.x86_64 |
EulerOS release 2.9 (Arm) |
v1.32 |
4.19.90-vhulk2103.1.0.h1433.eulerosv2r9.aarch64 |
v1.31 |
v1.30 |
v1.29 |
v1.28 |
v1.27 |
4.19.90-vhulk2103.1.0.h1144.eulerosv2r9.aarch64 |
EulerOS release 2.8 (Arm, end of maintenance) |
v1.27 or later |
None |
4.19.36-vhulk1907.1.0.h1350.eulerosv2r8.aarch64 |
v1.19.16 (end of maintenance) |
v1.19.10 (end of maintenance) |
4.19.36-vhulk1907.1.0.h962.eulerosv2r8.aarch64 |
v1.17.17 (end of maintenance) |
v1.15.11 (end of maintenance) |
4.19.36-vhulk1907.1.0.h702.eulerosv2r8.aarch64 |
EulerOS release 2.5 (end of maintenance) |
v1.27 or later |
None |
3.10.0-862.14.1.5.h687.eulerosv2r7.x86_64 |
3.10.0-862.14.1.5.h520.eulerosv2r7.x86_64 |
v1.19.8 (end of maintenance) |
3.10.0-862.14.1.5.h470.eulerosv2r7.x86_64 |
v1.17.9 (end of maintenance) |
3.10.0-862.14.1.5.h428.eulerosv2r7.x86_64 |
v1.15.6-r1 (end of maintenance) |
3.10.0-862.14.1.5.h328.eulerosv2r7.x86_64 |
v1.13.10-r1 (end of maintenance) |
3.10.0-862.14.1.2.h249.eulerosv2r7.x86_64 |
v1.13.7-r0 (end of maintenance) |
3.10.0-862.14.1.0.h197.eulerosv2r7.x86_64 |
CentOS Linux release 7.6 (end of maintenance) |
v1.32 |
3.10.0-1160.119.1.el7.x86 64 |
v1.31 |
v1.30 |
v1.29 |
v1.28 |
v1.27 |
3.10.0-1160.108.1.el7.x86_64 |
3.10.0-1160.15.2.el7.x86_64 |
3.10.0-1062.12.1.el7.x86_64 |
3.10.0-1062.1.1.el7.x86_64 |
3.10.0-957.21.3.el7.x86_64 |
Ubuntu 18.04 server 64bit (end of maintenance) |
v1.27 or later |
None |
4.15.0-171-generic |
4.15.0-136-generic |
OS |
Cluster Version |
CCE Turbo Cluster |
Latest Kernel |
VPC Network |
Tunnel Network |
EulerOS release 2.10 |
v1.32 |
4.18.0-147.5.2.15.h1109.eulerosv2r10.x86_64 |
v1.31 |
v1.30 |
v1.29 |
v1.28 |
v1.27 |
v1.25 |
v1.23 |
OS |
Cluster Version |
CCE Turbo Cluster |
Latest Kernel |
VPC Network |
Tunnel Network |
Huawei Cloud EulerOS 2.0 (supported by certain regions and server models. For details, see the console.) |
v1.32 |
5.10.0-60.18.0.50.r1083_58.hce2.x86_64 |
v1.31 |
v1.30 |
v1.29 |
v1.28 |
v1.27 |
v1.25 |
v1.23 |
EulerOS release 2.9 (restricted use. Submit a service ticket for confirmation.) |
v1.32 |
4.18.0-147.5.1.6.h841.eulerosv2r9.x86_64 |
v1.31 |
v1.30 |
v1.29 |
v1.28 |
v1.27 |
v1.25 |
v1.23 |
EulerOS release 2.3 (end of maintenance) |
v1.27 or later |
None |
3.10.0-514.41.4.28.h62.x86_64 |
v1.17 (end of maintenance) |
