- Function Overview
- Product Bulletin
- Billing
- Getting Started
User Guide
- Clusters
- Workloads
- Network
- Storage
- O&M
- Namespaces
- ConfigMaps and Secrets
- Auto Scaling
- Add-ons
- Helm Chart
- Permissions
- Settings
- Best Practices
API Reference
- Before You Start
- API Overview
- Calling APIs
APIs
- Autopilot Cluster Management
- Add-on Management for Autopilot Clusters
Autopilot Cluster Upgrade
- Upgrading a Cluster
- Performing a Pre-upgrade Check for a Cluster
- Performing a Post-upgrade Check for a Cluster
- Backing Up a Cluster
- Obtaining Details About a Specified Cluster Upgrade Booting Task
- Quota Management for Autopilot Clusters
- Tag Management for Autopilot Clusters
Chart Management for Autopilot Clusters
- Uploading a Chart
- Obtaining a Chart List
- Obtaining a Release List
- Creating a Release
- Updating a Chart
- Deleting a Chart
- Updating a Release
- Obtaining a Chart
- Deleting a Release
- Downloading a Chart
- Obtaining Chart Values
- Kubernetes APIs
- Appendix
- Billing
- Workloads
- Network Management
- Can PVs of the EVS Type in a CCE Autopilot Cluster Be Restored After They Are Deleted or Expire?
- Can CCE Autopilot PVCs Detect Underlying Storage Faults?
- How Can I Delete the Underlying Storage If It Remains After a Dynamically Created PVC is Deleted?
- Permissions
On this page
Show all
Help Center/
Cloud Container Engine_Autopilot/
Product Bulletin/
Product Release Notes/
Add-on Versions/
Cloud Native Log Collection Release History
Add-on Version |
Supported Cluster Version |
New Feature |
1.7.0 |
Supported CCE Autopilot clusters v1.31. |
1.4.5 |
Optimized the resource configuration. |
1.4.4 |
Fixed some issues. |
1.4.3 |
1.2.25 |
Parent Topic: Add-on Versions
