- Function Overview
- Product Bulletin
- Billing
- Getting Started
User Guide
- Clusters
- Workloads
- Network
- Storage
- O&M
- Namespaces
- ConfigMaps and Secrets
- Auto Scaling
- Add-ons
- Helm Chart
- Permissions
- Settings
- Best Practices
API Reference
- Before You Start
- API Overview
- Calling APIs
APIs
- Autopilot Cluster Management
- Add-on Management for Autopilot Clusters
Autopilot Cluster Upgrade
- Upgrading a Cluster
- Performing a Pre-upgrade Check for a Cluster
- Performing a Post-upgrade Check for a Cluster
- Backing Up a Cluster
- Obtaining Details About a Specified Cluster Upgrade Booting Task
- Quota Management for Autopilot Clusters
- Tag Management for Autopilot Clusters
Chart Management for Autopilot Clusters
- Uploading a Chart
- Obtaining a Chart List
- Obtaining a Release List
- Creating a Release
- Updating a Chart
- Deleting a Chart
- Updating a Release
- Obtaining a Chart
- Deleting a Release
- Downloading a Chart
- Obtaining Chart Values
- Kubernetes APIs
- Appendix
- Billing
- Workloads
- Network Management
- Can PVs of the EVS Type in a CCE Autopilot Cluster Be Restored After They Are Deleted or Expire?
- Can CCE Autopilot PVCs Detect Underlying Storage Faults?
- How Can I Delete the Underlying Storage If It Remains After a Dynamically Created PVC is Deleted?
- Permissions
Vulnerability Fixing Policies
Cluster Vulnerability Fixing SLA
- High-risk vulnerabilities:
- CCE Autopilot fixes vulnerabilities within one month after the Kubernetes community detects them and releases fixing solutions. The fixing policies are the same as those of the community.
- Emergency vulnerabilities of the operating system are released according to the operating system fixing policies and procedure. Generally, a fixing solution is provided within one month, and you need to fix the vulnerabilities by yourself.
- Other vulnerabilities:
Other vulnerabilities can be fixed through a normal upgrade.
Statement
To prevent customers from being exposed to unexpected risks, CCE Autopilot does not provide other information about the vulnerability except the vulnerability background, details, technical analysis, affected functions/versions/scenarios, solutions, and reference information.
In addition, CCE Autopilot provides the same information for all customers to protect all customers equally. CCE Autopilot will not notify individual customers in advance.
CCE Autopilot does not develop or release exploitable intrusive code (or code for verification) using the vulnerabilities in the product.
