- Function Overview
- Product Bulletin
- Billing
- Getting Started
User Guide
- Clusters
- Workloads
- Network
- Storage
- O&M
- Namespaces
- ConfigMaps and Secrets
- Auto Scaling
- Add-ons
- Helm Chart
- Permissions
- Settings
- Best Practices
API Reference
- Before You Start
- API Overview
- Calling APIs
APIs
- Autopilot Cluster Management
- Add-on Management for Autopilot Clusters
Autopilot Cluster Upgrade
- Upgrading a Cluster
- Performing a Pre-upgrade Check for a Cluster
- Performing a Post-upgrade Check for a Cluster
- Backing Up a Cluster
- Obtaining Details About a Specified Cluster Upgrade Booting Task
- Quota Management for Autopilot Clusters
- Tag Management for Autopilot Clusters
Chart Management for Autopilot Clusters
- Uploading a Chart
- Obtaining a Chart List
- Obtaining a Release List
- Creating a Release
- Updating a Chart
- Deleting a Chart
- Updating a Release
- Obtaining a Chart
- Deleting a Release
- Downloading a Chart
- Obtaining Chart Values
- Kubernetes APIs
- Appendix
- Billing
- Workloads
- Network Management
- Can PVs of the EVS Type in a CCE Autopilot Cluster Be Restored After They Are Deleted or Expire?
- Can CCE Autopilot PVCs Detect Underlying Storage Faults?
- How Can I Delete the Underlying Storage If It Remains After a Dynamically Created PVC is Deleted?
- Permissions
Show all
CCE Autopilot Cluster Patch Release History
Indexes
v1.31 (OBT)
CCE Autopilot Cluster Patch Version |
Kubernetes Version |
Feature Update |
Enhancement |
Vulnerability Fixing |
v1.31.1-r0 |
v1.31.1 |
Supported cluster v1.31. For more information, see Kubernetes 1.31 Release Notes. |
Fixed some security issues. |
v1.28
Feature Update |
Enhancement |
v1.28.7-r0 |
v1.28.6-r0 |
v1.28.5-r0 |
v1.28.4-r0 |
When YAML is used to create an application, the parameters that are not supported by CCE Autopilot and do not affect functionality were automatically ignored. |
v1.28.3-r0 |
v1.28.2-r0 |
v1.28.1-r10 |
Supported cluster v1.28. For more information, see Kubernetes 1.28 Release Notes. |
v1.27
Feature Update |
Enhancement |
v1.27.9-r0 |
v1.27.8-r0 |
v1.27.7-r0 |
v1.27.6-r0 |
v1.27.5-r0 |
v1.27.4-r0 |
v1.27.3-r30 |
Supported one-click configuration of monitoring alarms. |
v1.27.3-r20 |
Optimized the function of creating a NAT gateway by default during cluster creation so that applications can access the public network. |
v1.27.3-r10 |
Supported cluster v1.27. For more information, see Kubernetes 1.27 Release Notes. |
