Help Center/
      Bare Metal Server/
        Private Image Creation Guide/
        FAQ/
      How Do I Improve the UDP Packet Performance for x86 EulerOS 2.3?
        Updated on 2022-07-12 GMT+08:00
The iperf3 tool is used to test the maximum UDP bandwidth (1440-byte packets) and PPS (64-byte packets) with 0% packets lost. To acquire more UDP bandwidth and PPS, perform operations in this section.
- Log in to x86 EulerOS 2.3 in SSH mode and switch to user root.
 - Run the following command to back up /etc/sysctl.conf:
cp /etc/sysctl.conf /root/sysctl.conf_bak
 - Use vim to append the following content to /etc/sysctl.conf:
net.core.wmem_default =21299200 net.core.rmem_default=21299200
 - Run the following command to make the configuration take effect:
   Parent topic: FAQ
