Mapping Between BMS Specifications and Drivers
"-" in the tables indicates that this parameter is not required.
BMS |
Driver |
BMS Type |
OS |
Server Driver |
SDI Driver |
Hi1822 Normal NIC Driver/Management Component |
Hi1822 Offloading NIC Driver |
IB Driver |
GPU Driver |
Multipath Software |
bms-network-config |
s4 |
Windows |
x86 V5 BMS driver |
Required |
Required by BMSs with HBA cards |
Required |
CentOS/EulerOS/RedHat/Oracle |
x86 V5 BMS driver |
Required |
Required |
Ubuntu |
x86 V5 BMS driver |
Required |
Required |
SLES |
x86 V5 BMS driver |
Required |
Required |
Debian |
x86 V5 BMS driver |
Required |
Required |
d2 or io2 |
Windows |
x86 V5 BMS driver |
Required |
x86 V5 BMS driver |
Required |
Ubuntu |
x86 V5 BMS driver |
Required |
SLES |
x86 V5 BMS driver |
Required |
Debian |
x86 V5 BMS driver |
Required |
h2 |
x86 V5 BMS driver |
Required |
Required |
Required |
Ubuntu |
x86 V5 BMS driver |
Required |
Required |
Required |
p3 |
x86 V5 BMS driver |
Required |
Required |
Required |
Required |
Required |
Ubuntu |
x86 V5 BMS driver |
Required |
Required |
Required |
Required |
Required |
a/r/k (Kunpeng) |
CentOS/EulerOS/Ubuntu |
TaiShan BMS driver |
Required |
Required by BMSs with SDI cards |
Required by BMSs without SDI cards |
BMS Type |
OS |
Server Driver |
SDI Driver |
Hi1822 Driver/Management Component |
IB Driver |
GPU Driver |
s4 |
Windows |
x86 V5 BMS driver |
Required |
Required |
x86 V5 BMS driver |
Required |
Required |
Ubuntu |
x86 V5 BMS driver |
Required |
Required |
SLES |
x86 V5 BMS driver |
Required |
Required |
Debian |
x86 V5 BMS driver |
Required |
Required |
BMS Type |
OS |
Server Driver |
SDI Driver |
IB Driver |
GPU Driver |
s4 |
Windows |
x86 V5 BMS driver |
Required |
Required |
x86 V5 BMS driver |
Required |
Required |
Ubuntu |
x86 V5 BMS driver |
Required |
Required |
SLES |
x86 V5 BMS driver |
Required |
Required |
Debian |
x86 V5 BMS driver |
Required |
Required |
BMS Type |
OS |
Server Driver |
SDI Driver |
IB Driver |
GPU Driver |
s4 |
Windows |
x86 V5 BMS driver |
Required |
Required |
x86 V5 BMS driver |
Required |
Required |
Ubuntu |
x86 V5 BMS driver |
Required |
Required |
SLES |
x86 V5 BMS driver |
Required |
Required |
Debian |
x86 V5 BMS driver |
Required |
Required |
BMS Type |
OS |
Server Driver |
IB Driver |
GPU Driver |
a/r/k (Kunpeng) |
Required by BMSs with Hi1822 normal NIC |
