On this page
Show all
Cloud-Init 0.7.5
Updated on 2022-07-12 GMT+08:00
  1. Add the following key-value pair with an empty line above and below it:
    no_ssh_fingerprints: true
  2. Set ssh_pwauth to false. This parameter specifies whether to enable password login in SSH mode.
    ssh_pwauth: false
  3. Add preserve_hostname: false.
  4. Use the number sign (#) to comment out the following statements:
    mount_default_fields: [~, ~, 'auto', 'defaults,nofail', '0', '2']
    resize_rootfs_tmp: /dev
    ssh_deletekeys:   0
  5. Modify ssh_genkeytypes as follows:
    ssh_genkeytypes: ['rsa', 'dsa']
  6. Modify syslog_fix_perms as follows:
    syslog_fix_perms: root:root
  7. Add the following statements:
    network:
       config: disabled
    datasource_list: [ OpenStack ]
    NOTICE:
    For Ubuntu 14.04, the following line does not need to be added:
  8. Add the following statement after - final-message in cloud_final_modules:
    - power-state-change
  9. Check and modify the information in system info to make it consistent with the following content:
    system_info:
       default_user:
          name: linux  //Username for OS login
          lock_passwd: True   //True indicates that login using a password is disabled. Note that some OSs use value 1 to disable the password login.
         gecos: redhat
         groups: [audio, cdrom, dialout, floppy]   // (optional) Add the user to other groups that have been configured in etc/group.
          sudo: ["ALL=(ALL) NOPASSWD:ALL"]  //Current user has all the root rights.
          shell: /bin/bash   //Execute shell in bash mode.
       distro: sles
        paths:
          cloud_dir: /var/lib/cloud/
          templates_dir: /etc/cloud/templates/
          upstart_dir: /etc/init/
        ssh_svcname: sshd
    In the preceding command, change the value of distro based on the OS, such as distro: sles, distro: rhel, distro: ubuntu, distro: debian, and dustro: fedora.
  10. (Optional) For Ubuntu 14.04, perform the following operations:
    1. Use the vi editor to open the /etc/init/cloud-init-local.conf configuration file and modify the following configuration items:
      # cloud-init - the initial cloud-init job
      #   crawls metadata service, emits cloud-config
      start on mounted MOUNTPOINT=/ and mounted MOUNTPOINT=/run and stopped bms-network_config
    2. Run the following commands to configure the OpenStack source:
      dpkg-reconfigure cloud-init
      Run the vim /etc/cloud/cloud.cfg.d/90_dpkg.cfg command to open the configuration file and check whether the items are correctly configured in the file.
      # to update this file, run dpkg-reconfigure cloud-init
      If the configuration file content is consistent with the preceding command output, the configuration is successful.
