Help Center/ Cloud Application Engine/ Best Practices/ Connecting to the CodeArts Pipeline to Automatically Upgrade CAE Components/ Upgrading a CAE Component After Uploading an Image Built Using the Pipeline to the SWR Image Repository
Updated on 2025-01-17 GMT+08:00
Creating a Build Task
Create a build task for a code repository.
  1. Go to the CodeArts console and click Access Service in the upper right corner.
  2. Choose Services > Build.
    Figure 1 Selecting a service
  3. On the Build page, click Create Task. In the Basic Information area, set Task Name, Project, Code Source, Source Code Repository, and Branch, and click Next.
    Figure 2 Creating a build task
    Figure 3 Configuring basic build information
  4. Select a template for build and click Next. In this example, Java code is used. Therefore, select the Maven template.
    Figure 4 Selecting a build template
  5. On the Build Actions page, delete step Upload Software Package to Release Repository.
    Figure 5 Deleting step Upload Software Package to Release Repository
  6. Click Add step > Upload related > Build Image and Push to SWR > Add.
    Figure 6 Adding a step
  7. On the Parameters page, configure build parameters and default values by referring to Figure 7, and enable Runtime Settings. org_name indicates the SWR organization to which the image is uploaded. image_name indicates the name of the image uploaded to SWR. image_tag indicates the image tag or image version.
    Figure 7 Configuring custom parameters
  8. On the Build Actions page, configure step Build Image and Push to SWR. Set Organization to ${org_name}, Image Name to ${image_name}, Image Tag to ${image_tag}, Working Directory to the default value, and Dockerfile Path to the path in the code repository (in the example, the Dockerfile is in the root directory).
    Figure 8 Configuring step Build Image and Push to SWR
  9. Click Create and Run in the upper right corner, confirm the runtime parameter, and click Confirm.
    Figure 9 Running a build task
  10. On the Build History page, select the build task to view the build log.
  11. Log in to SWR and choose My Images to confirm that the image is uploaded.
Creating a Pipeline to Upgrade CAE Components
Create a CodeArts pipeline.
  1. Go to the CodeArts homepage.
  2. Choose Services > Pipeline. On the Pipeline page, click Create Pipeline.
    Figure 10 Selecting a service
    Figure 11 Creating a pipeline
  3. On the Create Pipeline page, set Name, Pipeline Source, Repository, and Default Branch, and click Next.
    Figure 12 Configuring basic pipeline information
  4. In Template, choose All > Blank Template and click OK.
    Figure 13 Selecting a template
  5. On the Task Orchestration page, click Stage. Click and change the names of stages 1 and 2 to Build and Deploy, respectively.
    Figure 14 Creating a pipeline
  6. Create a build job.
    • In the Build stage, click Job.
      1. On the NewJob page, click Build > Build > Add.
        Figure 15 Creating a build job
        Figure 16 Adding a build job
      2. Select the created build job and repository, set org_name, image_name, and image_tag as the pipeline parameters, and click OK.
        Figure 17 image_name
        Figure 18 image_tag
      3. On the Parameter Configuration page, add custom parameters by referring to Parameters.
        org_name: name of the SWR organization to which the image is uploaded, for example, for-test.
        image_name: name of the image uploaded to SWR, for example, cae-backend.
        image_tag: image tag or image version, for example, v1.0.
        swr_address: address of the SWR image repository. The format is swr.Region project name.myhuaweicloud.com.
        Figure 19 Adding custom parameters
    • In the Deploy stage, click Job.
      1. Enter CAE in the search box and click . Select the CAE Release extension and click Add.
        Figure 20 Adding a deploy extension
      2. Configure the extension parameters and click OK.
        • Region: Select a region for deployment, which is the same as the CodeArts region.
        • Environment: Select the environment to which the component belongs.
        • Application: Select the application to which the component belongs.
        • Component: Select the component to be upgraded. (You need to select a component that is deployed using the image in CAE.)
        • Component Source: Select Images.
        • Image Address: See Parameters.
        Figure 21 Configuring the extension parameters
      3. Click Save and Run. On the Execution Configuration page, confirm the configurations and click Run.
  7. View the pipeline execution result.
    Figure 22 Viewing the pipeline execution result
  8. Log in to CAE and check the component status. If Upgraded is displayed in the Last Change Status/Time column, the component has been upgraded using the CodeArts pipeline.
Parameters
Table 1 Parameters
Mandatory
Type
org_name
Yes
String
Name of the SWR organization to which the image is uploaded. You can log in to the SWR console to view the organization name.
image_name
Yes
String
Name of the image uploaded to SWR.
image_tag
Yes
String
Tag of the image uploaded to SWR.
swr_address
Yes
String
The format is swr.Region project name.myhuaweicloud.com. The region project name is region. For details, see Obtaining Values.
Image Address
Yes
String
Address of the image uploaded to SWR. Enter ${swr_address}/${org_name}/${image_name}:${image_tag}.
