Help Center/ Cloud Application Engine/ Best Practices/ Interconnecting GitLab with Jenkins for Automatic Build and Deployment on CAE/ Appendixes/ Obtaining the AK/SK
Updated on 2025-06-30 GMT+08:00
Obtaining the AK/SK
- Log in to CAE as the administrator.
- Click the username in the upper right corner and select My Credentials from the drop-down list.
- In the navigation pane, choose Access Keys.
- Click Create Access Key. After authentication, the AK and SK are created.
- Click Download.
- Obtain the AK and SK from the credentials file.
- Access Key Id is the AK.
- Secret Access Key is the SK.
Note:
- Each user can retain only two valid access keys.
- For security purposes, access keys are automatically downloaded only when they are generated for the first time and cannot be obtained from the console later. Keep the access keys secure.
Parent topic: Appendixes
