- Billing
- Getting Started
User Guide
- Overview
- Permissions Management
- Environment Management
- Application Management
- Component Management
- Instance Management
- Component Configurations
- Component O&M
- System Settings
- Key Operations Recorded by CTS
Best Practices
- CAE Best Practices
- Using CAE to Host Nginx Static File Servers
- Interconnecting GitLab with Jenkins for Automatic Build and Deployment on CAE
- Deploying Components Based on the Dependency Sequence Using the Jenkins Pipeline
- Deploying Spring Cloud Applications to CAE to Automatically Connect to the Nacos Engine
- Graceful Startup of a Spring Cloud Application
- Health Check
- Lifecycle Management
- Sending Event Alarms to WeCom
Connecting to the CodeArts Pipeline to Automatically Upgrade CAE Components
- Overview
- Upgrading a CAE Component After Uploading a Software Package Built Using the Pipeline to a CodeArts Release Repo
- Upgrading a CAE Component After Uploading a Software Package Built Using the Pipeline to the OBS Bucket
- Upgrading a CAE Component After Uploading an Image Built Using the Pipeline to the SWR Image Repository
- Configuring PromQL to Implement Custom Auto Scaling
- Configuring the Interconnection Between CAE and DEW to Help Applications Obtain Encrypted Secrets from DEW
- Deploying ASP.NET Core Applications to CAE
- Connecting the Network Through Enterprise Routes
- API Reference
- Component Management FAQs
Component Configuration FAQs
- Is Manual Scaling Still Effective When a Scaling Policy Is Configured?
- Can Components Be Scaled Without a Scaling Policy?
- Why Is My Instance Abnormal After Cloud Storage Is Configured?
- What Do I Do If a Component Becomes Not Ready?
- How Does CAE Support Dark Launch?
- How Do I Provide Prometheus Metrics for a Java Application?
- System Configuration FAQs
- Service Resources FAQs
Preparing the Jenkins Environment
Environment Description
If the Jenkins environment has been installed, skip this section.
Install Jenkins on a Linux VM. The following lists the environment information used in this practice. If you use an image for deployment, install Docker on the VM.
- VM: CentOS 7.9
- Jenkins: 2.331
- Git: installed using yum
- JDK: 11.0.8
- Apache Maven: 3.8.6
The following parameter needs to be added to start Jenkins:
-Dhudson.security.csrf.GlobalCrumbIssuerConfiguration.DISABLE_CSRF_PROTECTION=true
Otherwise, GitLab fails to interconnect with Jenkins. The error is as follows:
HTTP Status 403 - No valid crumb was included in the request
Downloading and Installing Related Software
- Download Jenkins:
- Install Git to pull code for building:
yum install git –y
- Download the JDK installation package:
https://www.oracle.com/cn/java/technologies/downloads/#java11
- Download the Maven installation package:
- Install Docker to pack the image and upload it to the image repository:
yum install docker
Verifying the Installation
- Git
- Git
[root@ecs-jenkins ~]# git version git version 1.8.3.1
- JDK
[root@ecs-jenkins jar]# java -version openjdk version "1.8.0_345" OpenJDK Runtime Environment (build 1.8.0_345-b01) OpenJDK 64-Bit Server VM (build 25.345-b01, mixed mode)
- Maven
[root@ecs-jenkins jar]# mvn -v Apache Maven 3.8.6 (84538c9988a25aec085021c365c560670ad80f63) Maven home: /root/app/maven/apache-maven-3.8.6 Java version: 11.0.8, vendor: Huawei Technologies Co., LTD, runtime: /root/app/jdk11/jdk-11.0.8 Default locale: en_US, platform encoding: UTF-8 OS name: "linux", version: "3.10.0-1160.76.1.el7.x86_64", arch: "amd64", family: "unix"
- Docker
[root@ecs-jenkins jar]# docker version Client: Version: 1.13.1 API version: 1.26 Package version: docker-1.13.1-209.git7d71120.el7.centos.x86_64 Go version: go1.10.3 Git commit: 7d71120/1.13.1 Built: Wed Mar 2 15:25:43 2022 OS/Arch: linux/amd64 Server: Version: 1.13.1 API version: 1.26 (minimum version 1.12) Package version: docker-1.13.1-209.git7d71120.el7.centos.x86_64 Go version: go1.10.3 Git commit: 7d71120/1.13.1 Built: Wed Mar 2 15:25:43 2022 OS/Arch: linux/amd64 Experimental: false
Figure 1 Version check - Git
