Help Center/ API Gateway/ Best Practices/ API Authentication/ Developing a Custom Authorizer with FunctionGraph
Updated on 2025-01-24 GMT+08:00
In addition to IAM and app authentication, APIG also supports custom authentication with your own authentication system, which can better adapt to your business capabilities.
Custom authentication is implemented using the FunctionGraph service. You can create a FunctionGraph function so that APIG can invoke it to authenticate requests for your API. This section uses basic authentication as an example to describe how to implement custom authentication with FunctionGraph.
General Procedure
  1. Developing a Custom Authentication Function
    Create a function for custom authentication.
  2. Creating a Custom Authorizer
    Create a custom authorizer in APIG to connect the function.
  3. Creating a Custom Authentication API
    Create an API with Custom authentication mode.
  4. Setting the Error Response
    To include the context field of the function response in the API response result, modify the gateway response.
  5. Mapping Frontend Authentication Parameters to Backend Parameters
    Add a system parameter to transfer the context information returned by the function to the backend.
  6. Verifying the API
    Call the API and check whether the context information of the function is successfully returned.
Create a function on the FunctionGraph console by referring to Creating a Function for Frontend Custom Authentication.
Create a function on the FunctionGraph page according to the following table.
Table 1 Function configuration
Create With
Select Create from scratch.
Function Type
Default: Event Function
Region
Select the same region as that of APIG.
Project
Projects group and isolate resources (including compute, storage, and network resources) across physical regions. A default project is provided for each Huawei Cloud region, and subprojects can be created under each default project. Users can be granted permissions to access all resources in a specific project. The selected region is used by default.
Function Name
Set this name as planned.
Enterprise Project
Enterprise projects group and manage resources across regions. Resources in enterprise projects are logically isolated. Select default.
Agency
An agency that delegates FunctionGraph to access other cloud services. For this example, select Use no agency.
Runtime
Select Python 3.6.
After the function is created, go to the function details page. On the Code tab page, copy the following code to index.py (if you are using a dedicated gateway, for which the authorizer_context_support_num_bool parameter has been enabled, the type of value in context can be boolean or number).
 3
 4
 5
 6
 7
 8
 9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
# -*- coding:utf-8 -*-
import json
def handler(event, context):
# If the authentication information is correct, the username is returned.
    if event["headers"]["authorization"]=='Basic dXN****cmQ=':
        return {
            'statusCode': 200,
            'body': json.dumps({
                "status":"allow",
                "context":{
                    "user_name":"user1"
    else:
        return {
            'statusCode': 200,
                "status":"deny",
                "context":{
                    "code": "1001",
                    "message":"incorrect username or password",
                    "authorizer_success": "false"
On the APIG console, choose API Policies > Custom Authorizers, click Create Custom Authorizer page, set Type to Frontend, and select the created function for Function URN.
On the APIs page of the APIG console, create an API by referring to Creating an API. Set the authentication mode to Custom, and select the custom authorizer created in the preceding section. After modifying the API, publish it.
If incorrect authentication information is carried in a request for the API, the response is displayed as follows:
{"error_msg":"Incorrect authentication information: frontend authorizer","error_code":"APIG.0305","request_id":"36e42b3019077c2b720b6fc847733ce9"}
To return the field in the function's context as the API response (if you are using a dedicated gateway, for which the authorizer_context_support_num_bool parameter has been enabled, the type of value in context can be boolean or number), modify the gateway response template. On the details page of the group to which the API belongs, navigate to the Gateway Responses area on the Gateway Information tab, and click Edit. Change the status code to 401, modify the response template with the following code, and click OK (no need to add double quotes for variables of the boolean or number type):
{"code":"$context.authorizer.frontend.code","message":"$context.authorizer.frontend.message", "authorizer_success": "$context.authorizer.frontend.authorizer_success"}
After the modification, if incorrect authentication is transferred when calling the API, the status code 401 is returned and the response result is as follows:
 {"code":"1001","message":"incorrect username or password","authorizer_success": "false"}
If the authentication is successful, the context information returned by the function can be transferred to the backend of the API. To do this, perform the following configurations:
On the APIs page, choose More > Edit in the row that contains the API, and go to the Define Backend Request page. Add a system parameter, specify the parameter type as Frontend authentication parameter, set the parameter name to the content of the context field in the function response, and set the name and location of the backend parameter to which you want to the map the frontend authentication parameter.
Verifying the API
After modifying the API, publish it again. If the authentication information carried in a request for the API is correct, the response result contains the X-User-Name header field whose value is the same as that of user_name in the context field of the authentication function.
