Help Center/
      API Gateway/
        Best Practices/
        API Openness/
        Routing gRPC Service Requests Using a Dedicated Gateway/
      General Procedure
        Updated on 2024-11-27 GMT+08:00
General Procedure
- Create an API.
Create a gRPC API with gRPCs as both the frontend and backend protocols.
 - Publish the API.
Publish the gRPC API in an environment.
 - Verify the API.
Use a gRPC client to test the gRPC service. If the server returns a response normally, the gRPC service is available.
   Parent topic: Routing gRPC Service Requests Using a Dedicated Gateway
