Introduction
Updated on 2025-01-16 GMT+08:00
You can use APIG to selectively expose your workloads and microservices in Cloud Container Engine (CCE).
Expose CCE workloads using either of the following methods. Method 1 is recommended.
  • Method 1
    Create a load balance channel on APIG to access pod IP addresses in CCE workloads, dynamically monitoring the changes of these addresses. When opening APIs of a containerized application, specify a load balance channel to access the backend service.
  • Method 2
    Import a CCE workload to APIG. APIs and a load balance channel are generated and associated with each other to dynamically monitor pod IP address changes. Expose workloads and microservices in CCE using these APIs.
Solution Architecture
Figure 1 Accessing CCE workloads (composed of pods) through APIG
Advantages
  • You do not need to set elastic IP addresses, reducing network bandwidth costs.
    Workload addresses in CCE can be accessed through a load balance channel that is manually created or generated by importing a workload.
  • Workload pod addresses in CCE can be dynamically monitored and automatically updated by a load balance channel that is manually created or generated by importing a workload.
  • CCE workloads can be released by tag for testing and version switching.
  • Multiple authentication modes keep access secure.
  • Request throttling policies ensure secure access to your backend service.
    Instead of direct access to containerized applications, APIG provides request throttling to ensure that your backend service runs stably.
  • Pod load balancing improves resource utilization and system reliability.
Restrictions
  • Only CCE Turbo clusters and CCE clusters using the VPC network model are supported.
  • The CCE cluster and your gateway must be in the same VPC or connected.
  • If you select a CCE cluster that uses the VPC network model, add the container CIDR block of the cluster in the Routes area of the gateway details page.
