Implementation Procedure
Creating a VPC
- Log in to the network console.
- In the navigation pane, choose Virtual Private Cloud > My VPCs.
- On the Virtual Private Cloud page, click Create VPC, and configure the parameters by referring to Table 1 and Table 2. For details, see sections "Creating a VPC" and "Creating a Subnet for the VPC" in the Virtual Private Cloud User Guide.
- Click Create Now.
- Repeat 3 to 4 to create VPC2 for running your backend service.
Creating a Gateway
- Go to the APIG console.
- In the navigation pane, choose Gateways.
- Click Buy Gateway.
Table 3 Gateway information Parameter
Billing Mode
Billing mode of the gateway. Select Pay-per-use.
Region
Select the region where the gateway is located. It must be the same as the region of VPC 1.
AZ
The AZ where the gateway is located. Select AZ1.
Gateway Name
Name of the gateway.
Edition
Select Professional. The edition cannot be changed after the gateway is created.
Scheduled Maintenance
Select a time period when the gateway can be maintained by technical support engineers. A period with low service traffic is recommended. For this example, retain the default value 22:00:00---02:00:00.
Enterprise Project
Select the enterprise project to which the gateway belongs. For this example, retain the default value default.
Network
Select VPC 1 and a subnet.
Security Group
Click Manage Security Groups and create a security group. Ensure that you have selected default for Enterprise Project.
Description of the gateway.
- Click Next.
- If the gateway configurations are correct, read and confirm your acceptance of the customer agreement and privacy statement, and create the instance.
Creating a Load Balancer
- Return to the network console.
- In the navigation pane, choose Elastic Load Balance > Load Balancers.
- Click Buy Elastic Load Balancer.
- Configure the load balancer information. For details, see section Load Balancer in the Elastic Load Balance User Guide.
Table 4 Load balancer parameters Parameter
Type
Type of the load balancer.
Billing Mode
By default, Pay-per-use is selected.
Region
Select the region where the load balancer is located. It must be the same as the region of VPC 2.
AZ
The AZ where the load balancer is located. Select AZ1.
Name
Name of the load balancer.
Enterprise Project
Select default.
Specification
Select Fixed – Application load balancing (HTTP/HTTPS) and Network load balancing (TCP/UDP) by default.
Network Type
Select Private IPv4 network by default.
VPC
Select VPC 2.
Frontend Subnet
Select a subnet.
- Click Next.
- Confirm the configuration and click Submit.
- Add a listener.
- Click the name of the load balancer. On the Listeners tab page, click Add Listener.
- Configure the listener name, frontend protocol, and port, and click Next.
- Configure the backend server group name, backend protocol, and load balancing algorithm. Then click Next.
- Add backend servers and click Next.
- Click Submit. The following figure shows the configuration.
Figure 1 Viewing the basic information and backend server group of the listener
Creating a VPC Peering Connection
- In the navigation pane, choose Virtual Private Cloud > VPC Peering Connections.
- Click Create VPC Peering Connection and configure the parameters.
Table 5 Configuring a VPC peering connection Parameter
Region
Select a region that is the same as the region of VPC 1.
VPC Peering Connection Name
Name of the VPC peering connection.
Local VPC
Select VPC 1.
Account
By default, My account is selected.
Peer Project
Select a project
Peer VPC
Select VPC 2.
- Click OK.
- In the displayed dialog box, click Add Now to go to the VPC peering connection details page.
- On the Associated Routes area, click Add Route.
- In the displayed dialog box, enter the route information.
Table 6 Local and peer routing information Parameter
Local routes
VPC
Select VPC 1.
Route Table
VPC 1 route table
Destination
Enter the service address displayed on the details page of the load balancer.
Peer routes
VPC
Select VPC 2.
Route Table
VPC 2 route table
Destination
Enter the private outbound address displayed on the details page of the dedicated gateway.
- Click OK.
Configuring a Route
- Return to the APIG console.
- Click the name of the created dedicated gateway or click Access Console.
- Click Change in the Routes area, enter the IPv4 CIDR block of VPC 2 where the load balancer you created is located.
- Click Save.
Creating an API
- On the APIG console, choose API Management > APIs, and click Create API > Create API.
- Configure the frontend information and click Next.
Table 7 Frontend configuration Parameter
API Name
Enter an API name.
Group
The default option is DEFAULT.
URL
- Method: Request method of the API. Set this parameter to GET.
- Protocol: Request protocol of the API. Set this parameter to HTTPS.
- Subdomain Name: The system automatically allocates a subdomain name to each API group for internal testing. The subdomain name can be accessed 1,000 times a day.
- Path: Path for requesting the API.
Gateway Response
Select a response to be displayed if the gateway fails to process an API request.
The default gateway response is default.
Authentication Mode
API authentication mode. Select None. (None: Not recommended for actual services. All users will be granted access to the API.)
- Configure the backend information and click Next.
Table 8 Parameters for defining an HTTP/HTTPS backend service Parameter
Load Balance Channel
Determine whether the backend service will be accessed using a load balance channel. For this example, select Skip.
URL
- Protocol: Set this parameter to HTTP.
- Backend Address: Enter the service address of the load balancer you created.
- Path: Path of the backend service.
- Define the response and click Finish.
Creating an ECS
- Log in to the cloud server console.
- Click Buy ECS.
- Configure the basic settings and click Next: Configure Network.
Table 9 Basic settings Parameter
Billing Mode
Select Pay-per-use.
Region
Select the region where the ECS is located. It must be the same as the region of VPC 2.
AZ
Select the AZ where the ECS is located.
CPU Architecture
The default option is x86.
Specifications
Select specifications that match your service planning.
Select an image that matches your service planning.
VPC
Select VPC 2.
Primary NIC
Select the subnet of the created VPC.
Security Group
Select the security group created for the dedicated gateway.
EIP
Select Not required.
ECS Name
Enter an ECS name.
Login Mode
Credential for logging in to the ECS. The default option is Password.
Username
The default user is root.
Password
Set a password for logging in to the ECS.
Confirm Password
Enter the password again.
Enterprise Project
Select "default".
- Read and confirm your acceptance of the agreement. Then click Create.
Debugging the API
- In the load balancer listener details, click View/Add Backend Server.
- On the Backend Servers page, add the created ECS.
- Go to the API Management > APIs page of the dedicated gateway, and choose More > Debug in the row that contains the API you created.
- Enter the request parameters and click Debug.
If the status code is 200, the debugging is successful. Otherwise, rectify the fault by following the instructions provided in Error Codes.
