General Procedure
- Create a function.
The function will be used for custom authentication.
- Create a custom authorizer.
Set the authorizer type to Frontend, and select the function created in the previous step.
- Create an API.
Set authentication mode to App, enable Two-Factor Authentication, and select the custom authorizer created in the previous step.
- Create a credential.
APIs that use app authentication require a credential to call. Create a credential to generate an ID and key/secret pair.
- Bind the credential to the created API.
APIs that use app authentication can be called only with bound credentials.
- Verify the API.
Call the API to check whether two-factor authentication is configured successfully.
