Implementation Procedure
- Create a policy.
- Log in to the APIG console and create a request throttling 2.0 policy.
- In the navigation pane, choose API Management > API Policies. Click Create Policy, and select Request Throttling 2.0.
- Configure basic policy information to meet your demands.
Table 1 Policy basic Information Parameter
Name
Set this name as planned.
Throttling
Select High-performance.
Policy Type
Select API-specific, which means measuring and throttling requests of a single API.
Period
Throttling period. Set this parameter to 60s.
- Configure basic throttling.
As required in 1, set Max. API Requests to 100 times per 60s and Max. User Requests to 5 times per 60s.
Table 2 Basic throttling Parameter
Max. API Requests
100
Max. User Requests
5
- Configure parameter-based throttling.
- As required in 2, enable parameter-based throttling, and define the Host parameter and rule.
- In the Parameters area, click Add Parameter, select header for Parameter Location, and enter Host for Parameter.
- In the Conditions area, click Add Rule, and set Max. API Requests to 10 and Period to 60 seconds. Then click
, and set the matching condition Host = www.abc.com.
- Click OK. The header matching rule Host = www.abc.com is generated, indicating that an API bound with this policy can only be called 10 times per 60s by requests whose Host header is www.abc.com.
- As required in 3 and 4, define multiple rules with parameter Path.
, and set the matching condition. - Add these three condition expressions: reqPath = /fc, reqPath = /list, and method = get.
- Click Set Lower Level.
- Put the two reqPath expressions in an OR relationship. This means the condition is met when either of the two paths is matched.
- Select reqPath = /list and method = get, click Set Lower Level, and select AND.
- Click OK. It indicates that APIs with path /list and method GET or APIs with path /fc bound with this policy can only be called 10 times per 60s.
- Configure excluded throttling.
As required in 5, enable excluded throttling. Add an excluded tenant with a threshold of 5 requests per 60s.
Table 3 Excluded throttling Parameter
Account ID
Tenant ID
Threshold
5
- Click OK. The request throttling 2.0 policy is configured.
- Bind this policy to an API.
- Click the policy name to go to the policy details page.
- In the APIs area, select environment RELEASE and click Bind to APIs. Select an API and click OK.
- Verify the API.
Call the API and verify whether the request throttling 2.0 policy has taken effect.
