Using WAF to Protect APIG
To protect API Gateway and your backend servers from malicious attacks, deploy Web Application Firewall (WAF) between API Gateway and the external network.
Solution Architecture
Advantages
Solution 1: Providing services using API group domain names is highly scalable.
(Recommended) Solution 1: Register API Group Debugging Domain Name on WAF and Use the Domain Name to Access the Backend Service
- Create an API group in a gateway, record the domain name, and create an API in the group.
- Log in to the APIG console, and choose API Management > API Groups.
- Click Create API Group > Create Directly and enter the group name.
- Click the name of the created group. The group details page is displayed.
- On the Group Information tab, view and record the debugging domain name. It is unique and cannot be changed. It can be accessed up to 1,000 times a day.
- On the APIs tab, click Create API > Create API to add an API.
- Add a domain name to WAF. Log in to the WAF console and choose Website Settings > Add Website. When configuring the Server Address, you need to enter the domain name of the API group and add a certificate. After adding a domain name, you need to whitelist the back-to-origin IP addresses, test WAF locally, and modify the DNS resolution settings of the domain name. For details, see Connection Process (Cloud Mode).
Users can use a public network client to access WAF with its domain name. WAF then uses the same domain name to forward the request to APIG. There is no limit on the number of requests that APIG can receive for the domain name.
- On the gateway details page, bind the domain name to the API group.
- Go to the APIG console, and choose API Management > API Groups.
- Click the name of a created group.
- On the Group Information tab, click Bind Independent Domain Name.
- In the dialog box that is displayed, add the domain name.
- Enable real_ip_from_xff.
- In the navigation pane of the APIG console, choose Gateways.
- On the Parameters tab page, set xff_index according to the actual IP address sequence.
When a user accesses WAF using a public network client, WAF records the actual IP address of the user in the HTTP header X-Forwarded-For. APIG specifies the actual IP address of the user based on the header.
When the header lists IP addresses in sequence, set xff_index to the zero-based index position of the client real IP in the list. For example: if the header value is real client IP, proxy server 1-IP, proxy server 2-IP, proxy server 3-IP, set xff_index to 0; if it is proxy server 1-IP, real client IP, proxy server 2-IP, proxy server 3-IP, set xff_index to 1.
Solution 2: Forward Requests Through the DEFAULT Group and Use Gateway Inbound Access Address to Access the Backend Service from WAF
- View the inbound access addresses of your gateway. There is no limit on the number of times the API gateway can be accessed using an IP address.
- Log in to the APIG console, and choose Gateways in the navigation pane.
- Click the gateway name or Access Console.
- On the Basic Information tab, view the inbound access.
- VPC Access Address: VPC private access address
- EIP: public network access address
- Create an API in the DEFAULT group.
- Click the name of the DEFAULT group.
- Click Create API > Create API to add an API.
- Add a domain name to WAF. Log in to the WAF console and choose Website Settings > Add Website. Set the Server Address to the inbound access of the gateway and add a certificate. After adding a domain name, you need to whitelist the back-to-origin IP addresses, test WAF locally, and modify the DNS resolution settings of the domain name. For details, see Connection Process (Cloud Mode).
- If WAF and your gateway are in the same VPC, set Server Address to the VPC access address.
- If your gateway is bound with an EIP, set Server Address to the EIP.
- On the gateway details page, bind the domain name to the DEFAULT group.
