Deleting a VPC Flow Log
Function
This API is used to delete a flow log.
Authorization Information
Each account has all the permissions required to call all APIs, but IAM users must be assigned the required permissions.
- If you are using role/policy-based authorization, see the required permissions in Permissions and Supported Actions.
- If you are using identity policy-based authorization, the following identity policy-based permissions are required.
Action
Access Level
Resource Type (*: required)
Condition Key
Alias
Dependencies
vpc:flowLogs:delete
Write
flowLog *
- vpc:FlowLogId
- vpc:FlogLogResourceType
URI
DELETE /v1/{project_id}/fl/flow_logs/{flowlog_id}
Table 1 describes the parameters.
| Parameter | Mandatory | Type | Description |
| project_id | Yes | String | Project ID. For details, see Obtaining a Project ID. |
| flowlog_id | Yes | String | Flow log ID |
Request Parameters
None
Example Request
DELETE https://{Endpoint}/v1/b2782e6708b8475c993e6064bc456bf8/fl/flow_logs/60c809cb-6731-45d0-ace8-3bf5626421a9 Response Parameters
None
Example Response
None
Status Code
See Status Codes.
Error Code
See Error Codes.
