Updating a VPC Flow Log
Function
This API is used to update a VPC flow log.
URI
PUT /v1/{project_id}/fl/flow_logs/{flowlog_id}
Table 1 describes the parameters.
Parameter |
Mandatory |
Type |
Description |
project_id |
Yes |
String |
Project ID. For details, see Obtaining a Project ID. |
flowlog_id |
Yes |
String |
Flow log ID |
Request Parameters
Parameter |
Mandatory |
Type |
Description |
flow_log |
Yes |
flow_log object |
FlowLog objects. For details, see Table 3. |
Parameter |
Mandatory |
Type |
Description |
name |
No |
String |
description |
No |
String |
admin_state |
No |
Boolean |
Example Request
- Change the name of the VPC flow log whose ID is f49f00f1-0f15-470a-a8c5-4e879e461c8d to flow-log-update.
PUT https://{Endpoint}/v1/b2782e6708b8475c993e6064bc456bf8/fl/flow_logs/f49f00f1-0f15-470a-a8c5-4e879e461c8d { "flow_log": { "name": "flow-log-update", "description": "update", "admin_state": false } }
Response Parameters
Parameter |
Type |
Description |
flow_log |
flow_log object |
FlowLog objects. For details, see Table 5. |
Parameter |
Type |
Description |
id |
String |
name |
String |
tenant_id |
String |
description |
String |
resource_type |
String |
resource_id |
String |
traffic_type |
String |
log_group_id |
String |
log_topic_id |
String |
log_store_type |
String |
admin_state |
Boolean |
status |
String |
created_at |
String |
updated_at |
String |
Example Response
{ "flow_log": { "id": "f49f00f1-0f15-470a-a8c5-4e879e461c8d", "name": " flow-log-update", "description": "update", "tenant_id": "b2782e6708b8475c993e6064bc456bf8", "resource_type": "port", "resource_id": "05c4052d-8d14-488f-aa00-19fea5a25fde", "traffic_type": "reject", "log_group_id": "05c4052d-8d14-488f-aa00-19fea5a25fdd", "log_topic_id": "a9d7dee7-37d2-4cba-a208-a016252aaa63", "log_store_type": "lts", "created_at": "2019-01-14T11:03:02", "updated_at": "2019-01-14T12:03:02", "status": "DOWN", "admin_state": false } }
Status Code
See Status Codes.
Error Code
See Error Codes.
