Querying a VPC Flow Log
Function
This API is used to query a VPC flow log.
URI
GET /v1/{project_id}/fl/flow_logs/{flowlog_id}
Table 1 describes the parameters.
Table 1 Parameter description
Mandatory
Type
project_id
Yes
String
Project ID. For details about how to obtain a project ID, see Obtaining a Project ID.
flowlog_id
Yes
String
Flow log ID
Request Parameters
None
Example Request
GET https://{Endpoint}/v1/b2782e6708b8475c993e6064bc456bf8/fl/flow_logs/1e10cd9d-742a-4d36-a9fd-aee9784336ff
Response Parameters
Table 2 Response parameter
Type
flow_log
flow_log object
FlowLog objects. For details, see Table 3.
Table 3 Description of the FlowLog field
Type
id
String
  • Flow log ID
name
String
  • Flow log name
  • The value can contain up to 64 characters, including letters, digits, underscores (_), hyphens (-), and periods (.).
tenant_id
String
  • Project ID
description
String
  • Flow log description
  • The value can contain no more than 255 characters and cannot contain angle brackets (< or >).
resource_type
String
  • Type of the resource for which that the logs to be collected.
  • The value can be:
    • port: a single network interface.
    • vpc: All network interfaces in a VPC.
    • network: All network interfaces in a subnet.
resource_id
String
  • ID of the resource for which that the logs to be collected.
traffic_type
String
  • Type of the traffic for which that the logs to be collected.
  • The value can be:
    • all: specifies that both accepted and rejected traffic of the specified resource will be logged.
    • accept: specifies that only accepted inbound and outbound traffic of the specified resource will be logged.
    • reject: specifies that only rejected inbound and outbound traffic of the specified resource will be logged.
log_group_id
String
  • Log group ID
log_topic_id
String
  • Log topic ID
log_store_type
String
  • Service that is used to store flow logs
  • The value can be:
    • lts: Log Tank Service (LTS)
admin_state
Boolean
  • Whether to enable the flow log function
status
String
  • Flow log status
  • The value can be:
    • ACTIVE: Enabled
    • DOWN: Disabled
    • ERROR: Abnormal
created_at
String
  • Time when the flow log is created
  • UTC time in the format of yyyy-MM-ddTHH:mm:ss
updated_at
String
  • Time when the flow log is updated
Example Response
    "flow_log": {
        "id": "35868d55-443e-4d5c-90a4-ac618dc45c1a",
        "name": "flow",
        "description": "just a test",
        "tenant_id": "b2782e6708b8475c993e6064bc456bf8",
        "resource_type": "port",
        "resource_id": "05c4052d-8d14-488f-aa00-19fea5a25fde",
        "traffic_type": "reject",
        "log_group_id": "05c4052d-8d14-488f-aa00-19fea5a25fff",
        "log_topic_id": "a9d7dee7-37d2-4cba-a208-a016252aaa63",
        "log_store_type": "lts",
        "created_at": "2019-01-14T11:03:02",
        "updated_at": "2019-01-14T11:03:02",
        "status": "ACTIVE",
        "admin_state": true
Status Code
See Status Codes.
Error Code
See Error Codes.
