- What's New
- Function Overview
- Getting Started
User Guide
- CodeArts Pipeline Usage
- Enabling and Authorizing CodeArts Pipeline
- Accessing CodeArts Pipeline
- Creating a Pipeline
- Configuring a Pipeline
- Grouping Pipelines
- Executing a Pipeline
- Checking a Pipeline
- Configuring a Change-triggered Pipeline
- Managing Pipeline Extensions
- Creating Service Endpoints
- Checking Audit Logs
- Reference
- CodeArts Release User Guide
- Best Practices
API Reference
- Before You Start
- API Overview
- Calling APIs
API
- Template Management
Pipeline Management
- Starting a Pipeline
- Obtaining Pipeline Statuses in Batches
- Obtaining Pipeline Status/Obtaining Pipeline Execution Details
- Obtaining Pipeline List/Pipeline Execution Status in a Project
- Deleting a Pipeline
- Querying Pipeline Details
- Editing a Pipeline
- Stopping a Pipeline
- Obtaining Pipeline Execution Records
- Creating a Pipeline With a Template
- Retrying a Pipeline
- Passing Manual Review
- Rejecting Manual Review
- Querying Pipeline Logs
- Obtaining the Pipeline Step Execution Output
- Querying Build Products on a Pipeline
- Group Management
- Rule Management
- Tenant-level Policy Management
- Project-level Policy Management
Extension Management
- Creating an Extension Version
- Creating an Extension Draft Version
- Creating a Publisher
- Updating an Extension Draft
- Publishing an Extension Draft
- Updating Basic Information of an Extension
- Binding an Extension to a Publisher
- Updating the Extension Icon
- Updating the Publisher Icon
- Deleting an Extension Draft
- Querying the Publisher List
- Querying the Available Publisher
- Querying the Available Extension List
- Querying the Basic Extension List
- Querying the Available Extensions by Page
- Querying the Extension List
- Querying Extension Indicator Configuration
- Query Extension Input Configuration
- Query Extension Output Configuration
- Querying All Versions of an Extension
- Querying Extension Version Details
- Querying the Extension Version
- Deleting a Publisher
- Querying Publisher Details
- Creating a Basic Extension
- Updating a Basic Extension
- Deleting a Basic Extension
- Uploading a Basic Extension
- Querying the Basic Extension Details
- Template Management (Old Version, Unavailable Soon)
Pipeline Management (Old Version, Unavailable Soon)
- Quickly Creating a Pipeline and Jobs with a Template
- Checking the Pipeline Creation Status
- Obtaining the Pipeline List
- Obtaining the Pipeline Status
- Obtaining the Pipeline Execution Status in a Project
- Application Examples
- Appendixes
- Change History
- Functions
Troubleshooting
- Pipeline Fails to Run Because Repository Not Found
- Pipeline Fails to Run Because the Test Suite Is Already in Progress
- Pipeline Fails to Run Because Job Not Found
- Pipeline Is Not Triggered at a Specified Time
- Execution Button Is Unavailable
- Inappropriate Reviewer Configured for the Manual Review Job
- Subpipeline Not Found
- Change-triggered Pipeline Fails to Run and an Error Message Is Returned: "authentication required"
- Pipeline Fails to Run Because Deployment Policy Not Found
- Videos
Example 3: Obtain the Pipeline Status
This section shows how to obtain a pipeline status by using APIs.
For details about how to call APIs, see Calling APIs.
A pipeline task has been created in CodeArts Pipeline.
Involved APIs
Use request parameters such as the user token and pipeline ID to obtain the pipeline status.
- Query the pipeline task execution status.
- API information
URI: POST v3/pipelines/{pipeline_id}/status
For details about this API, visit Obtaining the Pipeline Status.
- Example request
GET https://cloudpipeline-ext.ap-southeast-3.myhuaweicloud.com/v3/pipelines/{pipeline_id}/status
- Example response
{ "executor": "xxx", "status": "completed", "outcome": "success", "parameters": [ { "name": "serviceName", "value": "Test" }, { "name": "codeBranch", "value": "master" }, { "name": "releaseVersion", "value": "1.0.0" } ], "states": [ { "id": "state_3", "name": "Source code", "type": "stage", "status": "completed", "outcome": "success", "children": [], "start_time": "2020-09-01 17:13:18", "end_time": "2020-09-01 17:13:18", "elapsed_time": "0" }, { "id": "state_4", "name": "Build", "type": "stage", "status": "completed", "outcome": "success", "children": [ { "id": "Task_1", "name": "Default task", "type": "task", "status": "completed", "outcome": "success", "start_time": "2020-09-01 17:13:18", "end_time": "2020-09-01 17:16:22", "elapsed_time": "183", "error_code": null, "error_msg": null, "detail_url": null } ], "start_time": "2020-09-01 17:13:18", "end_time": "2020-09-01 17:16:22", "elapsed_time": "183" }, { "id": "state_5", "name": "Release repo", "type": "stage", "status": "completed", "outcome": "success", "children": [], "start_time": "2020-09-01 17:16:22", "end_time": "2020-09-01 17:16:22", "elapsed_time": "0" } ], "pipeline_id": "824e784b3f43492e99152a4....", "pipeline_name": "pipeline_test", "build_id": "xxxx", "start_time": "2020-09-01 17:13:18", "end_time": "2020-09-01 17:16:22", "elapsed_time": "184", "detail_url": "https://xxxxxx/pipeline/detail/824e784b3f43492e99152a....." }
- API information
