- What's New
- Function Overview
- Getting Started
User Guide
- CodeArts Pipeline Usage
- Enabling and Authorizing CodeArts Pipeline
- Accessing CodeArts Pipeline
- Creating a Pipeline
- Configuring a Pipeline
- Grouping Pipelines
- Executing a Pipeline
- Checking a Pipeline
- Configuring a Change-triggered Pipeline
- Managing Pipeline Extensions
- Creating Service Endpoints
- Checking Audit Logs
- Reference
- CodeArts Release User Guide
- Best Practices
API Reference
- Before You Start
- API Overview
- Calling APIs
API
- Template Management
Pipeline Management
- Starting a Pipeline
- Obtaining Pipeline Statuses in Batches
- Obtaining Pipeline Status/Obtaining Pipeline Execution Details
- Obtaining Pipeline List/Pipeline Execution Status in a Project
- Deleting a Pipeline
- Querying Pipeline Details
- Editing a Pipeline
- Stopping a Pipeline
- Obtaining Pipeline Execution Records
- Creating a Pipeline With a Template
- Retrying a Pipeline
- Passing Manual Review
- Rejecting Manual Review
- Querying Pipeline Logs
- Obtaining the Pipeline Step Execution Output
- Querying Build Products on a Pipeline
- Group Management
- Rule Management
- Tenant-level Policy Management
- Project-level Policy Management
Extension Management
- Creating an Extension Version
- Creating an Extension Draft Version
- Creating a Publisher
- Updating an Extension Draft
- Publishing an Extension Draft
- Updating Basic Information of an Extension
- Binding an Extension to a Publisher
- Updating the Extension Icon
- Updating the Publisher Icon
- Deleting an Extension Draft
- Querying the Publisher List
- Querying the Available Publisher
- Querying the Available Extension List
- Querying the Basic Extension List
- Querying the Available Extensions by Page
- Querying the Extension List
- Querying Extension Indicator Configuration
- Query Extension Input Configuration
- Query Extension Output Configuration
- Querying All Versions of an Extension
- Querying Extension Version Details
- Querying the Extension Version
- Deleting a Publisher
- Querying Publisher Details
- Creating a Basic Extension
- Updating a Basic Extension
- Deleting a Basic Extension
- Uploading a Basic Extension
- Querying the Basic Extension Details
- Template Management (Old Version, Unavailable Soon)
Pipeline Management (Old Version, Unavailable Soon)
- Quickly Creating a Pipeline and Jobs with a Template
- Checking the Pipeline Creation Status
- Obtaining the Pipeline List
- Obtaining the Pipeline Status
- Obtaining the Pipeline Execution Status in a Project
- Application Examples
- Appendixes
- Change History
- Functions
Troubleshooting
- Pipeline Fails to Run Because Repository Not Found
- Pipeline Fails to Run Because the Test Suite Is Already in Progress
- Pipeline Fails to Run Because Job Not Found
- Pipeline Is Not Triggered at a Specified Time
- Execution Button Is Unavailable
- Inappropriate Reviewer Configured for the Manual Review Job
- Subpipeline Not Found
- Change-triggered Pipeline Fails to Run and an Error Message Is Returned: "authentication required"
- Pipeline Fails to Run Because Deployment Policy Not Found
- Videos
Obtaining a Project ID
Obtaining a Project ID by Calling an API
A project ID can also be obtained by calling a specific API. For details, see Querying Project Information.
The API for obtaining a project ID is GET https://{Endpoint}/v3/projects/. {Endpoint} indicates the endpoint of IAM, which can be obtained from Endpoints. For details about API authentication, see Authentication.
{ "projects": [ { "domain_id": "65382450e8f64ac0870cd180d14e684b", "is_domain": false, "parent_id": "65382450e8f64ac0870cd180d14e684b", "name": "ap-southeast-3", "description": "", "links": { "next": null, "previous": null, "self": "https://www.example.com/v3/projects/a4a5d4098fb4474fa22cd05f897d6b99" }, "id": "a4a5d4098fb4474fa22cd05f897d6b99", "enabled": true } ], "links": { "next": null, "previous": null, "self": "https://www.example.com/v3/projects" } }
Obtaining a Project ID from the Console
A project ID is required for some URLs when an API is called. To obtain a project ID, perform the following operations:
- Hover over the username in the upper right corner and choose My Credentials from the drop-down list.
Choose My Credentials > API Credentials to view the project ID in the project list.
Figure 1 Viewing project IDsNOTE:
If there are multiple projects in one region, expand Region and obtain subproject IDs from the Project ID column.
