Help Center/ CodeArts Pipeline/ API Reference/ API/ Pipeline Management/ Setting Pipeline Resource-Level Permissions for Different Roles
Updated on 2025-12-04 GMT+08:00
Function
This API is used to set pipeline resource-level permissions for different roles.
Calling Method
For details, see Calling APIs.
URI
POST /v5/{project_id}/api/pipeline-permissions/pipeline/batch-role-permission
Table 1 Path Parameters
Mandatory
Type
project_id
Yes
String
Definition:
Project ID. For details, see Obtaining a Project ID.
Constraints:
N/A
Value range:
The value consists of 32 characters, including digits and letters.
Default value:
N/A
Request Parameters
Table 2 Request body parameters
Mandatory
Type
pipeline_ids
Yes
Array of strings
Pipeline ID list.
is_project_switch
Yes
Boolean
Whether to enable project permission configuration.
roles
Yes
Array of roles objects
Role details list.
Table 3 roles
Mandatory
Type
operation_authorize
Yes
Boolean
Permission configuration permissions.
operation_delete
Yes
Boolean
Permission to delete.
operation_execute
Yes
Boolean
Permission to execute.
operation_query
Yes
Boolean
Permission to query.
operation_update
Yes
Boolean
Permission to update.
role_id
Yes
Integer
Role ID.
Response Parameters
Status code: 200
Table 4 Response body parameters
Type
status
String
Definition:
Response status.
Value range:
N/A
Example Requests
POST https://(endpoint)/v5/071112d87d3e4ed49130c691936202e9/api/pipeline-permissions/pipeline/batch-role-permission
  "pipeline_ids" : [ "53acae73a3f44b2994f9b20a710721c6", "146542db758a4dc0995b44dff13e1933" ],
  "is_project_switch" : false,
  "roles" : [ {
    "operation_authorize" : false,
    "operation_delete" : true,
    "operation_execute" : true,
    "operation_query" : true,
    "operation_update" : true,
    "role_id" : 3
    "operation_delete" : false,
    "operation_update" : false,
    "role_id" : 4
    "role_id" : 5
    "operation_execute" : false,
    "role_id" : 6
    "role_id" : 7
    "role_id" : 8
    "role_id" : 9
Example Responses
Status code: 200
Response body.
  "status" : "success"
Status Codes
Status Code
200
Response body.
Error Codes
See Error Codes.
