Updated on 2026-01-07 GMT+08:00
Can I Import Grafana Views to AOM Dashboards?
Symptom
Can I import Grafana views to AOM dashboards?
Solution
Obtain the Prometheus statement of a Grafana view and then create a graph in AOM by using the Prometheus statement.
Procedure:
  1. Log in to Grafana and obtain the Prometheus statement of a Grafana view.
  2. Log in to the AOM 2.0 console.
  3. In the navigation pane, choose Metric Browsing.
  4. Select a target Prometheus instance from the drop-down list.
  5. Click Prometheus statement and enter the Prometheus statement obtained in 1.
  6. Select a metric and click in the upper right corner of the metric list.
  7. In the Add to Dashboard dialog box, select a dashboard, set a graph name, and click Confirm.
    Then you can view the Grafana view in AOM.
