Updated on 2026-11-17 GMT+08:00
Importing IP Address Entries to an IP Address Group in Batches
You can enter IP addresses, IP address ranges, and their descriptions in an Excel file and import the file to an IP address group. This allows you to quickly add multiple IP address entries.
  • The number of IP address entries that can be imported is limited. You can check the limited quota on the console.
  • Duplicate IP address entries will not be imported, for example:
    • Both the IP address ranges and their descriptions are the same.
    • The IP address ranges are the same but their descriptions are different.
  1. Click in the upper left corner and select the project.
  2. Click in the upper left corner and choose Network > Virtual Private Cloud.
    The Virtual Private Cloud page is displayed.
  3. In the navigation pane on the left, choose IP Address Groups.
    The IP address group list is displayed.
  4. In the IP address group list, click the name of the target IP address group.
    The basic information page of the IP address group is displayed.
  5. In the left corner above the IP address entry list, click Import.
    The dialog box for batch importing IP address entries is displayed.
  6. Click Download Template to download the Excel template.
  7. In the Excel file, enter IP address entries and their descriptions, and save the file.
    For details about the parameters in the Excel file, see Table 1.
    Table 1 Parameters for importing IP address entries
    Example Value
    IP Address Entries
    Mandatory
    In the IP Address Entries column, enter an IP address range or a single IP address on a separate line. You can enter:
    • An IPv4 address range, for example, 192.168.0.0/16
    • A single IPv4 address, for example, 192.168.10.10
    • An IPv6 address range, for example, 2001:db8:a583:6e::/64
    • A single IPv6 address, for example, 2001:db8:a583:6e::5c
    192.168.0.0/16
    Optional
    In the Description column, enter the description of the IP address or IP address range. Description can contain 0 to 255 characters, and cannot contain angle brackets (<>).
    ECS01
  8. In the dialog box for batch importing IP address entries, click Add, select the Excel file, and click Import.
    After the import is complete, you can view the newly imported IP addresses, IP address ranges, and their descriptions.
