Deleting an IP Address Group
This section describes how to delete an IP address group.
If you want to delete an IP address group with resources associated, you need to disassociate the IP address group from the resources first.
- Click
in the upper left corner and select the project. - Click
in the upper left corner and choose Network > Virtual Private Cloud. The Virtual Private Cloud page is displayed.
- In the navigation pane on the left, choose IP Address Groups.
The IP address group list is displayed.
- Perform the following operations to delete IP address groups.
- Delete a single IP address group:
- In the IP address group list, locate the row that contains the IP address group and click Delete in the Operation column.
A confirmation dialog box is displayed.
- Confirm the information and click OK.
- Delete IP address groups in a batch.
- In the IP address group list, select the IP address groups to be deleted.
- Click the Delete button located above the IP address group list.
If a message indicating that IP address groups with associated resources cannot be deleted is displayed, go to the resource details page and disassociate the IP address group from the resources first.
